bearings whinning....
Old Feb 19, 2006 | 11:20 AM
stevensLS1's Avatar
Default bearings whinning....
ok here's the deal im about to purchase a 6spd t.a with some mods: cam and full boltons. i asked the owner if the rear end is whinning and he said it is starting to. which bearing should i replace? i know some ppl at a dealership i use to work at and cant get it done cheap so which ones are they and should i throw some 4.11s while its exposed and a stud girdle? thanks in advance.
Old Feb 19, 2006 | 09:29 PM
stevensLS1's Avatar
TTT anyone?
Old Feb 19, 2006 | 10:14 PM
Scott@DrivelineSolutions's Avatar
LS1Tech Sponsor
I have seen just about every bearing go bad in various 10 bolts. The differential bearings are the easiest to inspect first and are the most common issue with low mileage cars.
Old Feb 20, 2006 | 11:10 PM
Gold Z's Avatar
There are only five bearings in the entire rearend....just replace all of them while it's apart and you are changing gears.
Old Feb 20, 2006 | 11:21 PM
camaromarc's Avatar
I agree, all the bearings come in one kit. Go for the 4.11s the stock gear might be the whinning
Old Feb 21, 2006 | 07:30 AM
slow trap's Avatar
axle bearings are nortorious for going south but as previously stated just be safe and replace them all.
Old Feb 21, 2006 | 10:01 AM
1313of1600's Avatar
Who sells the kit with all 5 bearings?
Old Feb 21, 2006 | 03:49 PM
camaromarc's Avatar
I got my kit from DTS. Check with the sponsors.
Old Feb 21, 2006 | 03:54 PM
95formulalt1's Avatar
I Just Had Mine Done....$540
Old Feb 22, 2006 | 03:27 AM
cantdrv65's Avatar
Post
I can almost guarantee you its the carrier bearings....after those start to whine the carrier develops play from the bad bearings and then shortly after you lose the ring and pinion gears....the yoke and axle bearings are probably fine.
Old Feb 22, 2006 | 08:33 AM
marv's Avatar
I believe Thunder Racing sells a complete kit for a 10 bolt rebuild...around $400.
