Who has broken there 10 bolt?
I want to see how many people have broken the stock 10 bolt that came in their car. What mods you had, what the car weighed, what 60' times you were pulling, what gears and tires you had, and what broke. What did you do to fix the problem.
Ill start:
car - 2001 bolt on M6
weight - 3250 lbs. (about)
60' times - low 1.7's
gears - 3.42's
Tires - ET streets
what broke - driver side axle
Fix - 12 bolt with 4.11's <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
<small>[ March 26, 2002, 12:07 PM: Message edited by: Bad Habit Bird ]</small>
Ill start:
gears - 3.42's
Tires - ET streets
Re: Who has broken there 10 bolt?
you mean their, not there.
Anyways,
car - 2000 SS
weight - stock
60' times - 2.10
gears - 3.42's
Tires - 555R
what broke - spider gears
Fix - replaced diff myself. $99 later was back on the road.
I broke it on a shift, not on a launch. Thanks to the twin disk clutch.
Anyways,
car - 2000 SS
weight - stock
60' times - 2.10
gears - 3.42's
Tires - 555R
Car: 2000 Z28
Weight: 3615
60' times: 2.0
Gears: Motive 4.10
Tires: Kumho Ecsta Supra 712
What Broke?: Driver's side axle twisted in half just outside the diff and passenger side axle bent the splines.
Fix: Moser 12-bolt w/ 4.10's and eaton posi.
Weight: 3615
60' times: 2.0
Gears: Motive 4.10
Car: 2000 Z28
Weight: 3615
60' times: 2.0
Gears: Motive 4.10
Weight: 3615
60' times: 2.0
Gears: Motive 4.10
Car: 2000 Z28
Weight: 3800
60' times: 2.0
Gears: Stock 3.42's
Tires: Nitto Dr's
What Broke?: Stock posi
Fix: Another stock 10 bolt, and I have finally ordered a Moser 12 bolt this year <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Weight: 3800
60' times: 2.0
Gears: Stock 3.42's
Tires: Nitto Dr's
Here is my Sad ut TRUE rear end Saga...... <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
FIRST TIME IT BROKE!!
-98z- minor bolton
-Weight-full??
-60's-1.89 But didnt Break on Launch!
-Gears-Rhichmond 4.10
-Tires- Nitto Drags
-What Broke-Spider Gears in Albern Broks as i Rounded the turn at the end of Track??
-Fix- Got Smart And bought a Locker. LockRite to be exact!!!
SECOND TIME!!
Couldnt Stand the locker, felt Flex out the wazoo!! Car wouldnt go Straight, Guess the
10 bolt flexed too much. Sold it to a buddy. He Broke it the SAME WEEKEND!! HEHE his car 2000 Z cam-headders. So i guess i didnt Break this one!!??
-Fix-Zexle Torsion pullout unit SLP
THIRD TIME!!
-98z cam and headders by now!
-Weight-same full?
-60's 2.0's babying it!
-Gears-Same ole Richmonds 4.10
-Tires-Nitto's DR
-What Broke- Zexle Broke on a 2-3 Shift!!
-Fix Another Zexle!! DARN IT Time to save for a 12 bolt!!!!!!!!
FOURTH TIME!!!! aka: three weeks later
-car-same 98...
-weight- same heavy
-60's-NONE BABY THIS POS!!!
-gears-Same ole Richmonds
-tires-STREET Tossed the nitto's to prolong the break!!!!
-what Broke- Richmods 4.10's broke 3!! Yes 3!! teeth of the pinion gear!!!!! WOW Just couldnt let that ricer smoke me. This was the FIRST time i got on it since last break. Still saving for a 12 bolt cant break now!!!! Broke on a 2-3 shift
-Fix- well had to sit for tree more weeks till i had the $$ then more time till rear came in. But the Moser 12 bolt, 33spline, Eaton HD, 1350 yolk, 4.30 gears... Should do the trick and Fix my problem...
all this was in a 6 Month period. NO JOKE!!!!
Take Care Fellas and Baby those 10 bolts!!! Hehehe tim 98z
-98z- minor bolton
-Weight-full??
-Tires- Nitto Drags
SECOND TIME!!
THIRD TIME!!
-Weight-same full?
-Tires-Nitto's DR
-car-same 98...
-weight- same heavy
98 ta
3450 lbs
1st time:
3.42 gears, stock rear end
what broke: driver side axle and 2 spider teeth off auburn diff. this was on BFG DR's leaving from 3 grand at the track.
fix: bought a whole rear end from a 97 camaro ss came with the HIGH TORQUE zexel
2nd time
4.10 gears, slp upgraded high torque zexel torsen
what broke: the whole damn diff grenaded broke all the little worm gears and broke the carrier in half, this was on a 1-2 shift. i also had et streets on!
fix: at last Moser alloy axles, eaton carrier with the carbon fiber clutch packs and a new set of motive 4.10's
i have 20 track passes on et streets pulling low 1.8's at 2200 elevation and the rear end is stil intact!!!!!
3450 lbs
1st time:
2nd time
car - 1999 cam/n20 M6
weight - 3600+ lbs
60' times - low 1.6's
gears - 3.73's
Tires - ET streets then Hoosier QTPs
what broke - Spider gears (3x)
Fix - 9" Ford with a wide array of gear changes (3.70 to 4.30 to 4.71) <img border="0" alt="[chug]" title="" src="graemlins/gr_chug.gif" />
<small>[ March 27, 2002, 07:27 AM: Message edited by: Fireball ]</small>
weight - 3600+ lbs
gears - 3.73's
99 SS M6
factory weight
2.1
3.42
goodyear eagle f1s
sheared half the teeth off the ring AND the pinion
rebuild, now I have a 12 bolt on order.
factory weight
2.1
3.42
goodyear eagle f1s
Time to add an A4 to the list.
car - 2000 Convertered A4
weight - 3580 lbs.
gears - 3.73's
Tires - BFG Drag Radials
what broke - Spider Gears took Ring & Pinion with it
Fix - 12 bolt with 3.42's <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
weight - 3580 lbs.
gears - 3.73's
car- 2000 SS H/C/I TNT 100 shot
weight - 3625
60' times - 1.6 to 1.8
gears - 3:73
Tires - Nitto 315 drags and ET Streets
what broke - Nothing yet <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Fix - Prayer <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
weight - 3625
gears - 3:73
"The Drag Racing Director"
Bird man,
You know about my rear end but , I will list the stuff for you again.
3540lbs
4:10 gears the 1st time, Moser 12 bolt & 4.56 the 2nd time.
Lanuch rpm 4,000 both times
Broke on the launch both times, axle the 1st time, posi the 2nd time.
No more problems, we put a spool in. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
I hope you are running real soon. I feel your pain. <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
Coach 02Z28 M6 Drag Racer <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
Mod's: They are coming! <img border="0" alt="[devil]" title="" src="graemlins/gr_devil.gif" />
<small>[ March 27, 2002, 06:35 PM: Message edited by: Coach 02Z28 ]</small>
3540lbs
I put my 12 bolt in last friday so I am definatly happy with the way my car is running now <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Cool man,
I hope to see you out a Temple Drgway when my Hot Rod is finished. It should be around the 2nd to 3rd weekend of April. Maybe we can have a friendly little Drag Race <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
if and when i grenade my 7.5 eaton carrier i will let yall know.. but so far its holding up pretty well .. and the moser alloy axles seem to be cool too..
this is 15-20 5000+rpm clutch drops with et streets at a drag strip
so far not a bad fix for slightly modded cars..
270 for the axles to my door and the carrier you can now pick up for 325
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Grease Monkey:
<strong>if and when i grenade my 7.5 eaton carrier i will let yall know.. but so far its holding up pretty well .. and the moser alloy axles seem to be cool too..
270 for the axles to my door and the carrier you can now pick up for 325</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Tell me about it, you've got enough stock rearend parts lying around the house to build 5 new 10-bolts. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
2000 SS convertable 3900lbs. with my fat a** and a full 15 lb bottle. low 1.70's all year best after a converter install 1.60 didn't totally break just didn't feel safe with it (long walk home). Moser 9" 3.89 gear locker 35 spline axles aluminum center section billet center support abs and trac. control. Also bmr lca lowering brackets. I don't think I will break this.
LS1Tech Co-Founder
Car- 98 SS M6
Weight - 3600 raceweight
60' times - 1.90
gears - 4.10 + a 3.73
Tires - Nitto 17" DR's
What broke - 2-4 teeth off the ring gear
Fix - N/A
I broke two gears, both from powershifting and driving abusively, neither time was at the track. I broke the 4.10 on a 1-2 powershift streetracing another car.
I have a Moser 9" in my 98 Formula. I have had a used posi go out, but my current setup is a soft locker and 4.10 and it works flawlessely. I cut 1.51 with this setup.
60' times - 1.90
Fix - N/A
