Gears kill topend?
Are you referring to the higher rpms (this would be encountered in every gear) making the engine feel as if it was 'over-revving'.
Or
Are you referring to high speed use?
Your terminal speed in gear should have reduced but at the benefit of reaching speeds quicker.
here they say you will get better topend.
Not considering the gears of your transmission at all, just spinning the driveshaft yoke at the rear end, with the 3.42 gear you must spin the yoke 3.42 times to make the tire turn one full revolution. On the other hand, with the 4.10 gears you will have to spin the yoke 4.10 times to turn the tire one full revolution. It just means you will have to turn about 20% more rpms with the 4.10 to go the same speed you went with the 3.42's in any given gear. But you'll get there a lot quicker.
3.73s are working out great so far in my car, 3.42s are not that bad given the fact you arent stock and are pushing at least 350rwhp.
Goin from 3.42s to 3.73s is not alot and thats what I wanted, now the car just feels lighter . And its more fun to drive while not killing my top speed or making it too sensitive on the throttle.
your limited to 151 at 6k in 5th gear... why is that so bad?
1. You can only go uptp 86mph (red line) so the 'range' of speed is much reduced. This means you will have to put an extra shift in, this all takes time and cost ground.
2. Due to the gearing it may feel like the engine is 'over-revving'. As soon as you hit the loud pedal you need to shift, it isn't making the best use of the torque/hp available. This is like, if you have ever been in a big diesel truck or lorry, 1st gear is often very short, so you think hay it will accelarate really well. But it doesn't it just tends to make a lot of noise and reaches the limiter really quickly. The low gear only exists to get the rig moving when fully laden.
4.10 gears could be veiwed similar, at the 1/4 mile they will really help fire the car out of the hole (grip dependant), but from a high speed roll they may lose they're affectivness.
You may find your car responds better in 4th @ 70mph, either that or run from a speed that better suits your gearing. 55-60mph in 3rd will be a good spot or 75-80mph in 4th.
The thing to remember is 4.10 gears give you better in gear accelaration, but at the cost of terminal speed in gear. This means that in most cases you have to shift more times to reach the same speed. So good fast and smooth shifting is far more important. As when you change gear you are NOT actually accelarating, so you need to minimise this period of non-accelaration in order to take advantage of the shorter gearing.
If you don't feel you can shift as fast as you would like (or is required) then your car with YOU as the driver may well actually be faster with 3.73 or 3.42 gears.
Take my Auto Z28 for example it has 2.73 rear gears, so 'in-gear' accelaration won't be as strong, but it will run to higher speeds in each gear. 70mph happens to be a good spot for it has it will kickdown to 2nd and be at ~4050rpm, it will then run all the way upto over 100mph before shifting into the 3rd and this gear will take me to the 158mph limiter. So very little time is lost in shifting.
Going from 3.42s to 4.10s will lower your absolute top speed, but it doesn't reduce your pulling power from a roll...it does the exact opposite. You're starting in the wrong gear, or you're slow on the shifts. Or if you're on a stock tire...you're getting some spin and you don't realize it.
now is 170mph so bad?
I think 3.73 would give you the best of both highspeed and low speed.
anyhow a top speed burst would prolly be done in 5th.
Consider this.
3.42 = in the area of 170mph -180mph depending how muchpower you got.
3.73 = 170 or a lil more
4.10 = 150 or so
