Problems with my 411 gears
Old Apr 13, 2006 | 05:04 AM
Long Beach's Avatar
Question Problems with my 411 gears
I just purchased some richmond 411 gears. the guy i bought them form said they came off a 2002 camaro ss. i have a 2002 firebird formula ls1 and all my gears and drive is stock. after i bought these ive been researching these and i found out that richmond dosent make 411 for the 7.5 10 bold rear. the guy i bought them form dosent know anything else except they are richmond 411 gears. what are my options at this point what do i need to make these fit. or would it be cheaper to just purchase a new set for the 10 bolt 7.5 rear.
Old Apr 13, 2006 | 05:35 AM
EPP's Avatar
EPP
If they are designed for the 10 bolt rear, then they will fit. They might be a 4.10 ratio. Since they came from a late model Camaro, I'd go ahead and use them. Bob
Old Apr 13, 2006 | 05:52 AM
Long Beach's Avatar
so it dosent matter if they are a 7.5 or a 8.2. as long as they are for a 10 bolt they will fit?
Old Apr 13, 2006 | 06:08 AM
FunkyTownFBody's Avatar
Some people use 4.10 and 4.11 interchangeably, 4.11 is the ford equivalent of 4.10. I think that there are a few manufacturers that make 4.11's for our stock 10 bolts, it's possible he's off on the brand...
It DOES matter if it's for a 7.5 or and 8.2, but since he has 7.5 (assuming here...), why are you worried if they'll fit?
Old Apr 13, 2006 | 06:15 AM
Long Beach's Avatar
because im not sure what he has i, i know i have 7.5 i dont want to be out the $ i paid for them. i dont really know too much about gears so thats why im trying to find out what my options are.
Old Apr 13, 2006 | 06:22 AM
Rebelord's Avatar
well, he might be off on the brand. I have Yukon 4.11s. They are no-**** 4.11s for my 7.5 rear. So, if he is off on the brand then they might very well be 4.11s. But if you dont know if they came out of a 7.5 or 8.2 then you need to find that out.
Ski
Old Apr 13, 2006 | 06:29 AM
8a8mfh's Avatar
You might look for some numbers and post them here.
The tooth count should be on the gears somewhere. Or count them and divide the ring gear tooth count by the pinion tooth count and you will get the ratio.
It may say on them GM 7.5, 7.625 or 7 1/2, 7 5/8.
Old Apr 13, 2006 | 07:33 AM
EPP's Avatar
EPP
Smile
7.5 and 8.2 are totally different, they cannot interchange. No 82-up F Body that i ever ran across ever came with a 8.2. The G Body chassis had a 8.5 to a 8.62 gear. if these gears came out of an '02 F Body, they will physically go into your car. Bob
Old Apr 13, 2006 | 12:07 PM
Long Beach's Avatar
thank you all for your help
Old Apr 13, 2006 | 02:19 PM
mrhzk35404's Avatar
Are you the guy that bought them from ebay for 9 bucks? There are two different carriers a 2 and a 3 series
Old Apr 13, 2006 | 03:59 PM
Long Beach's Avatar
yes the total cost was only $50, and how do i know if therse are a 2 or 3 series and how do i figure out what my car has.
Old Apr 13, 2006 | 08:27 PM
mrhzk35404's Avatar
yeah I emailed the guy about those gears and he never responded to me so I didnt bid on them. The 2 series gears are thicker than the 3 series.
Old Apr 14, 2006 | 12:45 AM
Long Beach's Avatar
he emailed me back and said they came out of a 2002 camaro ss. and he said that i have a 2002 and they came out of a 2002 and that they would fit and not to worry. but im not sure. i figured that they were inexpensive and if they dont work i wasnt out allot of money.
Old Apr 14, 2006 | 10:07 AM
mrhzk35404's Avatar
If the car the gears came out of was a 2.73 ratio then it is 2 series. Maybe my question was out of his league?
