When will my 10 bolt break?
Old 11-17-2006, 11:28 AM
  #41
99ls6TA's Avatar
My stock ten bolt broke after i put my procharger in and made about 3 1/4 mile passes but now i have a 12 bolt with 4.10s and love them definately the best choice to make!
Old 11-20-2006, 07:45 AM
  #42
Fedge's Avatar
Originally Posted by racinws6
from the research i have done, the crush sleeve in our 10 bolts is one of the big problems. the power our motors make, crushes the sleeve and messes up the backlash. this causes the pinion to become loose which is the roaring noise you hear. then its only a matter of time before you grenade it. a shim kit in place of the crush sleeve will fix this problem and extend the life of the 10 bolt.
mine was the housing, warping ever so slightly, causing deflection, chipping teeth off the ring and pinion, jamming the spiders, blah blah blah
Old 11-26-2006, 11:05 PM
  #43
camaromarc's Avatar
I put 50000 miles on my 10 bolt, countless passes at the track. I religously changed the fluid knowing it was on borrowed time. When it finnaly went I broke the drivers side axle at the splines. Luckly I had a spare axle and saved for a 9 Inch.
Old 01-16-2007, 06:02 PM
  #44
Bipolar's Avatar
So is there some kind of swap I can do with a rearend out of a different car or something? because I will never be able to afford a aftermarket 12 bolt rear setup...
Old 01-18-2007, 12:30 PM
  #45
Fbody98's Avatar
Iv made a coupple low 13 passes down the track on stack rear in a 98 formula and havnt had problems yet. now im waiting for a warm day to hook up my nos. see what happens
Old 01-22-2007, 02:58 PM
  #46
Jordan S.'s Avatar
I've had my 10 bolt in two cars now and was rebuilt about 2 1/2 years ago. Its got 3.73, thunder rebuilt kit, and eaton. Cheap *** fluid and Traction X or what ever its called. I dont have the ***** to put slicks and spray to it though. Its seen 1.7's all its life.
Old 02-10-2007, 02:59 PM
  #47
Ari G's Avatar
Has anyone put a spool or a locker in the 10bolt,have you broken it?
The old 7.5" before 1982 had weak diffrentials but if you put a locker or a spool they last much longer
Old 02-10-2007, 07:37 PM
  #48
mullenh's Avatar
get a c-clip eliminator least that will help, you can upgrade your axles that is the weakest part
  #49
mullenh's Avatar
the axle will still go
Old 02-22-2007, 06:01 AM
  #50
minesfaster's Avatar
whats the chances ill break mine. I have a m6 with nitto 555r's long tubes and a cam. i want to go to the track Will my chances of breaking it decrease if i dont launch it
Old 02-22-2007, 07:32 PM
  #51
mullenh's Avatar
you realy don't need to worry if your engine is in stock or near stock form.
Old 02-22-2007, 08:25 PM
  #52
Sluggish's Avatar
yes.....stay away from dropping the clutch at high rpms........always slide the clutch out easy......also be careful of hitting 2nd gear....it was break there also.....the last thing you want is break it will going 45 mph and an axel come out
Old 03-14-2007, 10:54 PM
  #53
TransAmJoe's Avatar
i had numerous passes on mine... then 1 day, just normal street drivin the, pinion gear decide to break into a few pieces
Old 03-26-2007, 09:36 PM
  #54
98TADRIVER's Avatar
broke 2 or 3 10bolts here, stepping up to a 12 bolt soon
Old 03-26-2007, 09:47 PM
  #55
ls1muscle's Avatar
Nitto drag radials = 10 bolt saver
Went to the track the other day and spun on every run, still managed a 1.84 60' though. Plus I give this car hell on the street, havent had any problems with the 10 bolt and it has 4.10 gears in it
Old 04-01-2007, 02:19 PM
  #56
Almostryan3's Avatar
I will be going with a Yank SS4000 pretty soon and a set of M/T E/T streets (26X10.50) car is just whisper lid, dynomax bullit dumped, and 3.73s (A4). Anyones guess on what I should be expecting, already saved about a thousand for a new rear just in case, but I would prefer to keep this one for a while.
Old 04-17-2007, 06:30 PM
  #57
FieroZ34's Avatar
I'm worried.
The rear end on our SS has started to make some abnormal noise when turning or traveling slowly, and I think it's the axle. The car is a 2002 SS M6, with every SLP option (CME, SLP lid, Auburn Diff, Bilstien suspension, etc). The car has just over 12,000 miles. It has never been to a track, and won't likely go to a track under our ownership. And it is babied on the street, with every way, shape, and form of the word. But when I do run it hard, I run it hard, very hard. I enjoy letting the back end fall out of place off the line, around turns, into 2nd, and into 3rd. If I go WOT, which is rare but happens, I go to redline, and slam the next gear hard. So when I do drive hard, it's very hard.
Anyways, the rear end is starting to make a little bit of noise. It isn't much, but on a car as otherwise flawless as this, I noticed it. I still have a warranty on the car, good for just under another year. If/when it does finally break, should I just have it replaced under warranty? Or should I put an aftermarket unit in it that I won't break? The problem here is that the car won't ever have more than the 345hp it's got. It will never get a K&N, heads, cam, or anything like that. So upgrading to a 12-bolt seems like a waste of money, especially if it doesn't drive like a stock piece (No noise, not a posi, etc). I'm not too versed on rear ends, if that isn't obvious yet.
So what would be the best option for a stock car that is very rarely driven hard, but when it is driven hard, making more power than every other stock F-body, it's driven very hard?
Old 04-22-2007, 08:00 PM
  #58
98 Z-28's Avatar
Im scared to run with my setup now on my 10 bolt I just replaced my ring & pinion im gonna save up so eventually i can get me a Moser 12 bolt and do 5k clutch dumps hopefully mine lasts as long as SDB's (above)
Old 05-11-2007, 02:22 AM
  #59
ls1owner4life's Avatar
How much does it cost for a replacement 10 bolt installed?
Old 05-15-2007, 05:18 PM
  #60
00PewterSS's Avatar
Mine broke last nite on a 1st to 2nd shift It was crazy loud before it broke, it was destined to die... It had countless track passes on it.
Brian
Quick Reply: When will my 10 bolt break?
