My experience w/ Strange Engineering
the parts themselves are probably quality products, i guess i meant the shitty/careless assembly of said products.
either way, once i get a good job and a different car, i'll make this one my toy and i'm sure a 12-bolt will be in my future.
It shows that on occasion, manufactures can have trouble with quality control (nothing new). Regarding Strange Engineering (SE), it does not show that this control is in the hands of SE exclusively.
SE does not manufacture all of their components of which they assemble. The most common complaint appears to be gear noise. Gears are manufactured by a variety of companies of which have their own tolerance levels and QC. Certainly set-up can have an impact.
On an assumption that SE installers have the equipment as well as experience, they should be able to setup a gear-set to specification. More then likely better then most who are inexperienced or repairing/building a rear-end on a one-time basis or limited basis. As previously discussed, different gear-sets due to materials, thickness and design have different harmonic frequencies. As a result, gear noise may be slightly different of which resonating frequencies change.
Can employees have a bad day, or rushing on a job, certainly. Do mistakes happen? Of course, as it appears to have with a few customers here. There are always two sides to a story of which we have not heard the other side.
From all the complaints in here, there is one fact that seems to be overlooked. …SE appears to be working (or have worked) with the customers to rectify that customer’s situation the best they could. THIS is what is important, as things to happen in a not-so-perfect world. You can’t satisfy everyone...some folks may expect noise levels stay exactly the same or less then a completely different component or design just because they spent 2000.00. Once again, tolerance levels are different for different folks. Different designs using different components more then likely will not have the same results.
I think I've discussed enough in here at this point...lol Have a great day guys!
I was pleasantly surprised by a response from Scott @ DLS in PMs... apparently he builds all the rear ends he sells in house. Meaning his passion for these things and obviously professional workmanship goes into the rear end youre purchasing, this is based on the word of many here who have dealt with Scott. Not to mention if something is to go wrong.. you know whos hands built the thing and you can talk to that person specifically.
From what I hear, if you want the bullet proof rear end and you are looking for good customer service... along with a rear end that is hand assembled by someone who knows whats going on and actually gives a damn about his customers, give your business to DLS. He seems to have a strong following here.
Those things I just mentioned about Scott and DLS will curb a LOT of the fears I have about purchasing a $2300+ rear end.
Theyll be getting my S60 order very soon. The Best V8 Stories One Small Block at Time
i hope my 10 bolt will last a long time as i have an auto, 2.73's, am mostly stock, don't beat the car, run street tires and will hardly ever see any track time, but if it does blow and a 12-bolt in my future, just from this post alone, scott seems like a standup guy to go with and if he sets them up in house rather than the mass produced idiots, i think he'd be a good place to research.
all the vendors on this site seem pretty good for the most part, always putting in their input. i'd be going for the vendors that set up the rear THEMSELVES instead of letting moser/strange set it up. with moser and strange, it seems like they use quality parts put together by quality idiots. if scott was building my rear with the quality parts, i'd feel 10 times more at rest that i was getting good parts put together RIGHT, and that is the most important thing!
race car parts will be loud.... rearend whine is not normally heard because most people that use them have loud exhaust/headers and no sound deadening...
i have a 12bolt moser and couldnt be happier... its a
2002 z28 with 12 bolt moser 4.10s, 28'' DR's, 6pnt CM roll bar, fire system, 408, procharged, FMIC, and bogart D10 rear wheels (fronts soon to come steve along with some STRANGE suspension and front brakes)
the bottom line is you putting race car parts on a street car... its gonna be loud... there may be 5% of the rearends that dont make noises but thats prolly because no one beat on them at the track..... i cant hear my rear but thats because a dynomouth exhaust and LT headers are filling the inside of my race car.....
i hear many people talking about rearend noises or little pops and creaks from suspension parts or chassis parts....
Its because race car parts are for race cars
if you want you car to be quiet and subtle and easy to drive steer clear of performance mods..... the drivability will get worse... theres just no way around it.
sorry if that was harsh but i dont like ******* vendors just becuase the parts make a little sound or whine... its just part of it.... get some headers and straight exhaust... youll never here after that
Theyll be getting my S60 order very soon.i'm tired of people defending companies that produce a poor product when large sums of money was spent just because they're brand cheerleaders. that's what i'm sick of.
no one is talking about "a lil gear whine". any gears make noise if you listen hard enough and your exhaust is quiet. they're talking about howling because idiots whose job is to build these rears can't set up gears right.
