Moser 9" install guide!
How do I put this thing in?!
I searched, and can't find a single install guide for it. Does anyone have a comprehensive (step by step, socket sizes, whatnot) for installing it? Thanks!
i had to grind the torque arm mount a little on mine to make my BMR Torque Arm fit on it. i don't know about the stock one though?
Also, does your new rear have the sway bar mounting brackets on it already? if not, you're gonna have to get some (BMR sells them) and get 'em welded on!
Option 1
Weld on Sway Bar Brackets
If you have a mig welder and are up for the task, you can weld the brackets on. Install the sway bar with the endlinks. Mock up the brackets and mark the welding area to grind away the paint. Take out the brackets and using a grinder, grind all the paint off the area. Position the brackets in place, and tack weld it. If the position is good, then weld it in all the way. Bolt the bar into place using the stock hardware on the new bracket. Use some black paint and paint over all the welded areas to help stop rust.
Option 2
Shop Install Sway Bar Brackets
For most people, and if you dont have a welder, you need to take your car up to a shop to have them weld the sway bar brackets into place with the sway bar to position it.
