2.73 to 3.73...
Old Aug 21, 2006 | 02:46 AM
98hardtopZ's Avatar
Default 2.73 to 3.73...
how hard would it be to swap gears on the ol' ten. i have several presses so that wouldnt be an issue...but overall?
Old Aug 21, 2006 | 06:53 AM
keliente's Avatar
see for yourself.
http://www.keliente.com/gears.htm
Not really something I recommend unless you have some gear experience.
Old Aug 21, 2006 | 08:03 AM
98hardtopZ's Avatar
gotta start somewhere tho...if i cant do it then i can throw it in the back of a truck and take it somewhere right?
Old Aug 21, 2006 | 08:35 AM
keliente's Avatar
Hmm...'gotta start somewhere'. How much work have you done to your car? Do you have a full set of tools, including measurement instruments like dial indicator gauge, pinion depth checker, rotational torque wrench, microabrasive defibrulator...ok so you don't need the last one, but you will need a lot of different tools for the install.
Getting the setup right on a gear set is crucial. Pinion depth, preload, backlash, are so important. Get it wrong and you will ruin a gearset in 5 miles, or have the howling pinion bearing from hell. If you have a friend who has done a few and can help, that would really be great...otherwise you might just want to pony up the $250ish and take it somewhere.
Sure if you got stuck you could take the rear end somewhere...removing the rear end isn't hard but it'd be another couple hours of your time you could have saved.
Good luck with whatever you decide...
Old Aug 21, 2006 | 01:09 PM
98hardtopZ's Avatar
actually i have most of that, i have machine shop access three days a week and thats where to presses are... for the old lathes we have the dial indicators and such...gotta torque wrench. how much are used 10 bolt rears tho? could they be had for around the same price as gears/proffesional installation? if so i could just get someones who upgraded to a moser or 9" right?
Old Aug 21, 2006 | 01:23 PM
keliente's Avatar
Yeah, probably. Used 10 bolts (often with aftermarket gears) run from $300-$500. That'd be a good idea...then you'd have your stocker as a backup when needed.
Old Aug 21, 2006 | 01:24 PM
98hardtopZ's Avatar
sweet...but a stocker prob wont last long on a m6 will it? especially if i throw some stickies on the back..better start saving up for the moser...
Old Aug 21, 2006 | 01:26 PM
keliente's Avatar
https://ls1tech.com/forums/gears-axles/510589-when-will-my-10-bolt-break.html
Totally depends. Mine was good for around 250 passes on BFG's and then broke on e.t. streets. I consider myself lucky to have it last so long.
I have a friend named Ben with an hugger orange car. If he looks at it the wrong way, his rear end breaks.
Old Aug 21, 2006 | 01:32 PM
98hardtopZ's Avatar
man..going fast and having horsepower is so expensive...
Old Aug 21, 2006 | 01:42 PM
keliente's Avatar
Welcome to the wonderful world of modifying and racing... It only gets worse.
Old Aug 21, 2006 | 04:19 PM
98hardtopZ's Avatar
being 17 and in school cant really make the money id like too...i turn 18 in two weeks so hopefully i can get something above minmum wage around here...
