WTF is wrong with my rearend?!
Old Jun 25, 2002 | 08:27 PM
DriveATransAm's Avatar
Default WTF is wrong with my rearend?!
So ive been wondering if my rearend is going and ive hated the idea of taking the ta cover off and seeing. it seemed to do one wheel burnouts at the track, and sometimes leave two marks on the street. it seemed a little noisey too. so today i opened her up, and NOTHING. nothing more but a bunch of really dark fluid. no teeth in there floating around (unless they came out of the drain hole and into the bottle). ill have the check all the fluid that came out just to make sure. the teeth all looked fine on the posi. but HEREs the wierd part. you arent supposed to be able to turn the pas. wheel if you hold the driver side wheel (in N). i can though! and when you turn one wheel, the other one is supposed to turn the same direction. but mine didnt. i tested it on two other rearends, and they both turned forward, and i couldnt turn the pas. wheel when holding the driver side one. i thought the stock ones were all gear driven, so if your posi goes out, its the gears that went.
i slapped it back together and went for a drive and there is still a little grinding when turning. is that normal?
so whats the deal with it? it acts like it has a broken posi when the rearend is in the air, but i cant find any broken teeth <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Jun 26, 2002 | 03:15 PM
JR HAWK 9's Avatar
Default Re: WTF is wrong with my rearend?!
We have a torsen differential, it's a torque biasing diff. You are confusing the old time clutch-type of limited slip, where, as you stated when you turn one wheel, the other side will turn the same way. I had my rear in the air and noticed that exact same thing you noticed.....it's normal.
As far as your noises, I couldn't tell you...but don't worry about your tires turning the same way with a Torsen differential <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
<small>[ June 26, 2002, 03:17 PM: Message edited by: JR HAWK 9 ]</small>
Old Jun 26, 2002 | 04:17 PM
i tried it on my stock 2.73 rearend, and my buddys 3.42 rearend too though?
Old Jun 26, 2002 | 04:25 PM
JR HAWK 9's Avatar
I know if I turn one wheel, the other wheel will turn the other way. I don't know if I hold one wheel if I am able to turn the other one though, never tried that. I have never had a problem with one wheel wonders either....
Old Jun 27, 2002 | 12:11 AM
please <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
Old Jun 27, 2002 | 10:47 AM
dunaway's Avatar
thta happened with my 97 formula...you need to get a new posi unit...
Old Jun 27, 2002 | 01:33 PM
what am i supposed to try?
Old Jun 27, 2002 | 02:31 PM
Superman's Avatar
If you had broken spider gears it wouldn`t drive at all.. any gears for that matter. I`d say your clutches are going in the posi. Was the fluid really dark?
Old Jun 27, 2002 | 04:25 PM
the fluid was very dark. i thought the clutches too, but then someone told me these didnt have any clutched <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
hell if know, all i know is that they make the car go <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Jun 27, 2002 | 04:41 PM
jmX's Avatar
jmX
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Dan99Hawk:
<strong>If you had broken spider gears it wouldn`t drive at all.. any gears for that matter. I`d say your clutches are going in the posi. Was the fluid really dark?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I broke my spider gears and the car still drove. However, it was dodgy, and made loud gunfire noises every once in a while, usually when turning but sometimes while going straight.
I replaced my diff with a takeoff unit from SLP..parts cost me $99 and it took about 4-6 hours to put in myself.
(EDIT: im not saying thats what happened to this car, he'd obviously see chunks of metal from the spider gears if thats what had happened)
<small>[ June 27, 2002, 04:41 PM: Message edited by: jmX ]</small>
Old Jun 28, 2002 | 12:30 AM
<img src="http://www.horist.com/~royboy82/rear/_0186.jpg" alt=" - " />
ok, whats bad <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> this was taken before i put it in.
Old Jun 28, 2002 | 12:41 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Roy try this guy Anthony, he works for Strange I met him at Strats...
furyusvip@aol.com
