Strongest 10 bolt ratio?
The stock torsen will be replaced with a TR2, and the axles will be replaced with Moser's. So it'll all basically be new.
I won't be doing any drag racing, auto-x only and on street tires only. Car is an M6.
The lower the number of gears on the ring gear, the stonger it should be right? What about the pinion? Is it the smaller the diameter of the pinion, the stronger, or the opposite?
For road racing 3.23-3.42 work well...
Well the ring gear is going to be 7.625" in diameter no matter what, so having a less gear teeth means the teeth should be stronger.
I don't think I'm trying to fix a major problem with duct tape
I won't be doing any drag racing, and I'll always be running street tires, so it shouldn't be too big of a problem. Axle hop shouldn't be a problem, I will be spending a pretty penny on the rear ends suspension.
The toughest ratio would be the tallest you could get- 2.56's are easy to find but you wouldnt really want them. 3.73's are a good compromise but are borderline.
Is this correct?
As far as contact, that is debated. Some people say that a 4.11 (37-9) is stronger than a 4.10(41-10) and vice-versa. I personally would rather have the 4.10 since it has more teeth and should have more contact area, which means it distribute the power better to the ring gear. Some others would say the thicker teeth of the 4.11 are better, either way it is marginal and the ratio itself is the main factor, material being equal.
A stock torsen really sucks on auto-x.
Kumho MX's are a really nice set of street/auto-x tires.
So, the 2.73's have fairly large teeth and the most teeth on the pinion (15) of the popular combo's, so that means its got more teeth contacting the ring gear at the same time.
So for a 10 bolt to live get the ratio in your range with the least amount of teeth on the ring gear, and the most on the pinion gear. Then have it mirconited, and installed by a seasoned proffesional. Don't forget to replace the torsen, axles and get a diff. cover...man these 10 bolts can get expensive
