Slips out of 3rd, why?
Old Aug 22, 2002 | 09:16 PM
Zshark's Avatar
Default Slips out of 3rd, why?
The shark will slip out of 3rd if the car is decelerating in gear or under very low throttle. Did the previous owners just miss alot of 2nd to 3rds and the gear is worn? It seems to do this more when it is cold.
Old Aug 24, 2002 | 03:59 PM
wrencher's Avatar
wrencher
Default Re: Slips out of 3rd, why?
M-6 right r&r & overhaul time your 3rd speed syncronizer is toast <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
Old Aug 24, 2002 | 04:31 PM
NastySSoo's Avatar
Ditto, bad syncro!!
Old Aug 26, 2002 | 02:49 PM
99Hawk#196's Avatar
I think there was a tech. bullitin out about this.
Tom <img border="0" alt="[Firebird]" title="" src="graemlins/formula.gif" />
Old Aug 26, 2002 | 07:01 PM
pbperformance's Avatar
does the trans go into gear ok and then pop out or does it grind going in and when you let off the clutch its in neutral?
if it is the first problem then its either the 3rd gear itself and the slider is tapered or the fork is worn out.
if it is the second problem then more than likely its the syncro.
just trying to help ya out .....
mike @ poorboys performance
Old Aug 26, 2002 | 09:33 PM
Zshark's Avatar
The tranny will slip into 3rd just A-ok, but for example, i go to school on a freaking mountain and on the way down, rather than fry the brakes (because it will!) i just ride the engine down. It will stay in fourth fine, and second fine, but not third. Now this doesnt happen CONSISTANTLY, just sometimes and mostly when it is cold. To be honest this problem has led me to to the 1, 2, 4 shift around town, and only when i want to embarass somebody do i use third.
Old Aug 26, 2002 | 09:34 PM
Zshark's Avatar
Please lie to me and say that it is fine, i only want to replace stuff that doesnt need replacing (like my exhaust), and not the other way around <img border="0" title="" alt="[Roll Eyes]" src="images/icons/rolleyes.gif" />
Old Aug 27, 2002 | 11:03 AM
well its one of two things . either the gear and sleeve are tapered or you have slack in the gear train assembly . i doubt its the syncro, but i have been wrong before.
Old Aug 27, 2002 | 01:04 PM
Zshark's Avatar
Poor boy performance, could i get an estimate on a rebuild?
Old Aug 27, 2002 | 01:28 PM
well i am not a sponcor so i will not list any quotes but if you want to call me the number is 1-877-poorboys my name is mike
Old Aug 28, 2002 | 09:53 AM
99Hawk#196's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Zshark:
<strong>The tranny will slip into 3rd just A-ok, but for example, i go to school on a freaking mountain and on the way down, rather than fry the brakes (because it will!) i just ride the engine down. It will stay in fourth fine, and second fine, but not third. Now this doesnt happen CONSISTANTLY, just sometimes and mostly when it is cold. To be honest this problem has led me to to the 1, 2, 4 shift around town, and only when i want to embarass somebody do i use third.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Like I said earlier. There is a TSB(warranty) out on this problem. "Going down a hill in third and it pops out".....that's the TSB....bad syncro.
Old Aug 28, 2002 | 10:23 AM
D&D's Avatar
D&D
99 Hawk is correct. You have a snycro problem, the part of the syncro that your having a problem with is the 3/4 slider assembly. There are syncro teeth on the inside of the slider. These teeth start as a point then get wider then taper back narrower. The taper holds the trans in gear. Once the taper is gone, there is nothing to hold the trans in gear, my guess is that your slider is 1) not machined right on the coast side or 2)the teeth are beat up from wear an tear. While on the subject,there are three parts that make up a "syncro" there are syncro teeth on each gear, there are slider assembly's (that engage each gear) and there are blocker rings (act as a brake for each gear so slider can slide over gear) To say you have bad "syncro's" is a very wide open statement.
Old Aug 28, 2002 | 10:37 AM
99Hawk#196's Avatar
I don't have the problem(knocking on wood), but dealerships/warranty work give me the *******. My question is: with this problem, could you 'hold it in 3rd gear' while going down hill?Rather than have a dealer rip appart your tranny <img border="0" alt="[whiner]" title="" src="graemlins/gr_cry.gif" />
Old Aug 28, 2002 | 11:52 AM
Zshark's Avatar
I am the third owner of the car, and i know nothing of a warranty (it is a 98), do you think they would do it for free. I guess im asking if it is a recall situation. Plus i got headers and all that jive.
Old Aug 28, 2002 | 02:08 PM
99Hawk#196's Avatar
<strong>I am the third owner of the car, and i know nothing of a warranty (it is a 98), do you think they would do it for free. I guess im asking if it is a recall situation. Plus i got headers and all that jive.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I think if there is a TSB out....it's covered. Page Ken C. in the SLP lounge, he has a website (I believe) that list the TSB be year and model.
Old Aug 28, 2002 | 09:53 PM
MelloYellow's Avatar
FWIW, the 3rd gear fork is the most common one to bend. There is an aftermarket steel 3->4 replacement fork available during rebuilds.
