Difference between spool and mini spool
Old Sep 16, 2002 | 06:23 PM
sited12's Avatar
Default Difference between spool and mini spool
I know a spool wont work on the street because the stress of turns will eventually break it. But i have no idea what a mini spool is. Is it just a small spool but still the same idea so that means no street use.
Old Sep 16, 2002 | 07:53 PM
justin sutton's Avatar
Default Re: Difference between spool and mini spool
A mini spool is the same except it goes in your factory carrier where a full spool replaces your carrier.I have drove a spool on the street I doubt you will break it.
Old Sep 16, 2002 | 07:54 PM
Bob2of3's Avatar
Wheels up Director
A mimi spool goes inside the differential where the spider gears are to lock the axles. Most mini spools are designated for circle track only probably cause the can't handle the shock loads of drag racing the way a full spool can. Either one you're gonna have to exercise extreme caution if driven on the street
LAter <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Sep 16, 2002 | 08:17 PM
Coach 02 A3 Z/28's Avatar
"The Drag Racing Director"
sited12,
I drive a full race spool and 5.13 gears on the street with no problems at all. If you have a M6 Hot Rod and drag race at the track you need to get a spool. Just my 2 cents. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
<small>[ September 16, 2002, 08:18 PM: Message edited by: Coach 02 M6 Z/28 ]</small>
Old Sep 16, 2002 | 08:36 PM
sited12's Avatar
How much do you drive yours on the street. I was going to go with 4.56 gears and a spool is cheaper than posi. Do you get the problem with the back tires skipping around turns. I drive my car almost every day for an average of 40 miles so will it hold up. Even if it doesnt i could just keep replacing it cause they dont cost much.
Old Sep 16, 2002 | 09:31 PM
I have been driving mine about 35 miles a day and race her at the track more than anyone on this site with no problems at all. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Go for it, I would. <img border="0" alt="[devil]" title="" src="graemlins/gr_devil.gif" />
Coach
Old Sep 16, 2002 | 10:04 PM
sited12's Avatar
Sweet what set up do you have. I was thinking of a Strange 12bolt with the full spool and 4.56 gears. What do you guys think of that set up.
Old Sep 16, 2002 | 10:16 PM
I have a Moser 12 bolt with 33 spline axles, a strange spool with 5.13 gears and a TA cover everything BMR has. Oh wait a minute, I am having Madman install his bad *** Tq arm. If you need a tq arm and drive ahaft loop for sale. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
I think your set up will rock. <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
Coach
Old Sep 16, 2002 | 11:29 PM
sited12's Avatar
Yeah i am starting from the back then working my way up. First the rearend then probably heads and cam. Then a TH400 with a line lock.
