How much does a moser 12bolt weigh?
Old Mar 22, 2007 | 12:19 PM
1mofbody's Avatar
Default How much does a moser 12bolt weigh?
Just curious how much does a complete moser 12bolt weigh? Thanks for any help..
Old Mar 22, 2007 | 01:21 PM
BlackScreaminMachine's Avatar
Internet Mechanic
I dont have a scale but I do have one on saw horses going in the car tonight, safe to say I need nother person to help me. I bet its in the upper 100 pound range,
Old Mar 22, 2007 | 06:04 PM
DuronClocker's Avatar
I was able to lift mine off our company truck and into my garage 50 feet away without too much trouble. Definitely a bit heavier than a 10-bolt though.
I haven't fully assembled my 9" yet so I haven't picked it all up at once to have an idea of comparison, but after weighing out the individual pieces of my 9" (strange aluminum center section), it is 181lbs not including the nuts/bolts, which would probably add another 5lbs or so.
Old Mar 22, 2007 | 06:23 PM
lethal93ta's Avatar
I dont know about a 12 bolt but my 9 inch was 207, thats narrowed 4 inches over all so that should cut a couple of lbs off, but i have a back brace welded on there that probably evens the weight out from being narrowed, my stock rear was 141, talk about fun I put the 9 inch in the car by myself, carried it out of my blazer into my garage, probably only 30 feet and put it on a floor jack to lift it up in there, I picked it up again to weight it after I had it on there. I will never move it again with the axles and everything on there its a lot to handle.
Old Mar 22, 2007 | 06:49 PM
lol
That 141 sounds about right for the stock rear. I weighed mine at 138, but that didn't include the cover bolts
None of my weights listed here have backing plates included, they were another 13.5lbs or so.
Old Mar 23, 2007 | 04:22 AM
EPP's Avatar
EPP
Smile
Mike decided to have us remove his Moser 12 bolt and install a Moser 9 inch rear in it's place. Mike's car is at the horsepower level to where the 12 bolt may not handle the close to 700 rwhp, and the nine inch is a stronger unit. We ordered this 9 inch with a spool, and an aluminum center unit.
We weighed the Moser 12 bolt after we removed it, and it weighed 188 pounds. The Moser 9 inch with the spool and the aluminum center section, weighs 181.5 pounds, lighter than the 12 bolt!!!!
Bob
Old Mar 23, 2007 | 10:55 AM
Internet Mechanic
Being that my rear was just reassembled last week, everything except brake hardware, but had the tq arm still attactched. That thing with fluid was a mother **** to carry. I am a pretty strong guy and the other one helping me isnt a weakling either.
It was HEAVY.
Old Mar 23, 2007 | 02:46 PM
Lythropus's Avatar
Bob
12 bolt was also a spool?
Old Mar 23, 2007 | 03:11 PM
2001z's Avatar
all i know is my 9in was heavy as hell trying to drag it under the car
Old Mar 24, 2007 | 06:09 AM
EPP's Avatar
EPP
Smile
No, the 12 bolt was a truetrac, so it is not comparing the same things. That was mentioned in this build-up that I created, but I didn't copy that section, as I was going for the weight of the 12 bolt here.
A 12 bolt with a spool would be lighter than the nine inch with a spool, but I'd opt for the nine inch. Bob
Old Mar 24, 2007 | 07:24 AM
tuff's Avatar
8 SEC SLOPPY SHOT!!!
It sounds like your spliting hairs on weight.I sold my 12 bolt and went with the 9 in it is just so much more of a rearend.Thanks Bob for hooking me up this rearend looks badass.
Old Mar 24, 2007 | 01:46 PM
1mofbody's Avatar
Thanks guys for all the help, I estimated 200 pounds on mine for shipping. Should be close enough.
Old Mar 25, 2007 | 06:53 AM
EPP's Avatar
EPP
Smile
Not a problem, thanks! Bob
