Ford 9" questions
Jason
<strong>Alright, I have a few questions. How wide is a ford 9" housing sized for a 98 camaro? I have the opportunity to buy a 9" housing that is 59.25" wide, with 2 31spline axles for 70 bucks. I'd like to put together a bargain 9" for my car as I really do not want to spend 2k on something that you can buy at any junkyard for 400 fully assembled. I know about the spring perches and all that, but 2k+ is a complete ripoff. How far about are the spring perch locations? What needs to be done about the tourque arm mount? Anything else I need to know? Also, how much is a 3rd member with posi? I know making this rear end will be a time taking process with trial and error. But I figure for 70 bucks and if I can get most if not all the measurements I need I might beable to cash in under 1k. TIA
Jason</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Sorry...but your not going to find moser axles and centersection in a junkyard. Moser doesnt just buy a 9" in a junkyard for $400 and then sell it to you for $2000. Remember, you get what you pay for. Bight the bullet and get the moser or youll be spending over $2000 trying to get stuff right.
<small>[ October 07, 2002, 02:43 PM: Message edited by: promod1955 ]</small>
I'm not sure with my Moser 9" if the wheels sit at exactly the stock location or not.
If you use your stock rearend as a guide, even cannibalize it, you can get a donor 9" to work. Just most folks don't know how to weld'n sh^t. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Jason
You need the brackets for your LCA's too, again most folks don't have access to a shop that will weld in all the brackets etc. for a decent price...
I am running a used center section that at one time I paid $500 for it but I redid it and did a locker this time.
Jason
<strong>How wide is a ford 9" housing sized for a 98 camaro? I have the opportunity to buy a 9" housing that is 59.25" wide.
Jason</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">If that's 59.25" from housing flange to housing flange, then it is correct for a 4th gen.
Do you know where that housing came from?
Was it out of a certain car?
Steve
<small>[ October 14, 2002, 10:09 AM: Message edited by: Aircooled ]</small>
Jason
Find yourself a Center Section, and you can be in a 9" $1200 or less (Depending on the Center you find) w/ lil' to no headache. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
JM $.02
<strong>I'm ALL for doing budget 9" rears, but personally I wouldn't mess w/ a used 9" Housing. Like John said Moser sells the housing and axle package complete w/ all bracktery and TA Bracket for ~7-800. A BARGAIN if you ask me. I can't see where its cost/time effective to jack with trying to put Spring/Shock/TA/PHR Brackets, AND buy Axles, and Housing Ends.
JM $.02</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">TTT, moser is now charging $985 for the package not such a "deal" anymore
