8.5 10 bolt possible?
Old May 26, 2007 | 09:49 PM
Brief Encounter's Avatar
Default 8.5 10 bolt possible?
I was wondering if anyone has swapped for a 8.5 10 bolt. It doesmt seem like it would cost alot, whith the exception of making and mounting a TA mount. The bigger ring gear should be able to handle sticky tires with an automatic if done properly.
So has anyone successfully swapped to this rear, or even considered it?
Old May 26, 2007 | 09:59 PM
Revelation Z28's Avatar
i think you would have better luck with fabbing a ford 8.8 than a 10.5 10 bolt. they basically need the same fabrications to be made to work.
Old May 27, 2007 | 10:21 PM
axisT6's Avatar
The 8.5 10 bolt is great when built properly. It also has a larger pinion shaft and pinion bearings then the 12 bolt. An 8.5 10 bolt with alloy shafts, and a tru-trac would be a nice piece.
Old May 27, 2007 | 10:24 PM
styoung's Avatar
i think it might be hard to find one, i think they stopped making those 25 years ago, im not sure, i know i have one in my 1980 camaro and that took a lot of abuse, so they are very strong.
Old May 27, 2007 | 10:45 PM
chicane's Avatar
Oops. Strike one.
This is not at all true. It does however, have a larger pinion shaft and bearings than that of the Truck 12 bolt... but, not the passenger car differential. Which includes the OE 67-70, the newer KTRE, Moser and Strange 12 bolt housings.
Although... I have seen a very limitied and few 8.5's converted to the late model f-body. I have always wondered why it has not been done more. With the 8.5" housings being so plentiful... all you have to do is come up with the torque arm mount... and that has been done a few different ways already. In fact, SummersBrothers used to do conversions of the early 12 bolt into the late 80's f-body.
Old May 27, 2007 | 11:20 PM
mzoomora's Avatar
14 Second Truck Club
The late 80's GNX had a 8.5 with a torque arm, and I believe it was a bolt on piece. They are strong rears, and if you could get a later model one they have 30 spline axles(89-up) and larger OD carrier bearings(99-up). You could also upgrade the earlier carrier bearings to a larger ID since that was a weak link (spun bearings on the carriers as pretty common).
Old May 27, 2007 | 11:56 PM
chicane's Avatar
The GNX set-up looks like this:
Old May 28, 2007 | 12:27 PM
axisT6's Avatar
Originally Posted by chicane
Oops. Strike one.
You are correct, the truck 12 bolt was what I was talking about. I normally mention the truck axles as those are more common.
Old May 28, 2007 | 10:27 PM
So, with a little work, IE- TA mount, disk brakes, shock mounts... it would take some abuse.
Im thinking of going this route, and if it doesnt take the power, I can always go 9".
But I could prolly get this done for considerablly less than a 9" or 12 bolt, so its worth a shot.
Old May 29, 2007 | 12:36 PM
Sluggish's Avatar
good luck finding one...I have been on the lookout for 1 for year for my monte carlo
Old May 29, 2007 | 12:52 PM
Jon5212's Avatar
I had a 87 GMC full size Jimmy and I'm pretty sure it was a 8.5" 10 bolt. But it makes me wonder cause if it was a 7.5" i put that truck through hell and back until the rear finally let loose at 175K miles. That being 2 minute long burnouts with 33 inch tires.
edit: and several mudding outtings etc etc... and it wasn't even the ring/pinion gears i blew up the spider gears in the diff. But i'd be willing to spend a few hundred to convert a 8.5" than dish 2500 on a 9 inch.
Old May 29, 2007 | 02:40 PM
mzoomora's Avatar
8.5's are everywhere, 1/2 ton trucks, vans, full size cars, 70's cars, etc.
Trying to find a direct olt in one for a g-body is hard since it was only available in Grand Nationals.
Old May 29, 2007 | 06:29 PM
RamAir02TA77's Avatar
That would be cool if someone could come up with something that would work. It would be nicer to have a cheaper alternative then buying a 12 bolt or 9'' or something.
Old May 30, 2007 | 08:43 AM
Jon5212's Avatar
I'd like to see someone post that has done this and what it took to fab it up to fit? Cause i could probably one of these rears out of a junkyard for 50 bucks and totally build it for about 800-1000.
Old May 30, 2007 | 08:53 AM
7.0 camaro's Avatar
i was thinking about doing the same thing. for me i think the 9'' would be overkill. an old man told me one time that a 8.5 could be better than a 12 bolt or a 9''. at the time i didn't believe them. but you see all these mustang guy's biulding their 8.8's instead of going to a 9''. makes you wonder why.
Old May 30, 2007 | 09:22 AM
RaNsOm's Avatar
I believe the 94-96 Impala SS's had the 8.5" as well.
Old May 30, 2007 | 10:07 AM
96lt1m6's Avatar
i have fabbed up many 3rd gens to have the 8.5 rear they are plentiful 74-81 f-bodies,nova's as well,86-87 GN of course.this company makes the bolting in of any rear end is possible(except IRS).i will NEVER run a 9" due to the weight and how inefficient the ring and pinion are set up in there(not talking crap,they are strong!!!!!)there are many 9sec GN's with a 8.5 still in it,weld axle tubes,moser axles,auburn or ?,spool,c-clip eliminator...
most 9'' guys say that they like it for ease of gear change, pfffttt!just how many times are you gonna change your gears out?
http://www.g-forcesuspension.com/pag...og/i.php/81/55
Old May 30, 2007 | 10:14 AM
Jon5212's Avatar
So if I bought this kit along with a 10 bolt from a 1/2 ton pickup it would bolt in besides the welding of the control arm brackets? And the welds can be done without warping the housing?
Old May 30, 2007 | 10:19 AM
Bryan @ Speed Inc.'s Avatar
that would be great to find someone in the chicagoland area that could fab one up for less than a moser 12 bolt.....
Old May 30, 2007 | 10:24 AM
96lt1m6's Avatar
why would you use one from a truck?
bolt pattern is 5on5,have to change that!
find one from an f-body in the salvage yard these rears ar still plentiful.
