Read end trouble please help
im thinking the problem is with your abs sensor at the top of the pumkin. take it out and have a look.
The cap was cut for clearence as was the housing (aka the tube oiler) hole. Nothing to worry about.
As for the differential case... those are normal rough finish, machining marks. Also, nothing to worry about... unless... you want to relieve the stress risers and lessen the possibility of case failure (which you are not using it in a manner in which I would worry about anyway).
Parrafin or DINO oil = OK (a straight 140wt or an 85/140 would be choice)
Synthetic = NO
Friction modifier = MUST USE
