Another 9" question...nodular center section?
Old Nov 13, 2002 | 01:59 PM
RAGEman's Avatar
Default Another 9" question...nodular center section?
The 9" I'm purchasing (used) was made by Moser. Does anyone know if Moser offers the nodular iron center section as an option or what? If not, what is Moser's center section made out of? Would it be necessary to purchase a new (nodular) center section in order to make the rear fully reliable? Thanks.
Old Nov 13, 2002 | 02:34 PM
Thumpy's Avatar
Default Re: Another 9" question...nodular center section?
Alan, you can get the nodular center section as an option. I'm not running one yet. It was about the only thing that held when the torque arm broke!
Jeff
Old Nov 13, 2002 | 02:53 PM
Fireball's Avatar
2 weak points in a 9" are factory cast centers (I run a nodular Strange center) and flimsy pinion support (I run a billet pinion Support)
If you are looking for bulletproof (and I suppose thats what you are doing since you want a spool) then get a strange nodular center <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Nov 13, 2002 | 05:16 PM
RAGEman's Avatar
Whoa, it's Thumpy!!! Hey, Jeff, what's happening? How's Sarah doing? Are y'all about ready for Thumpy Jr. or Thumpette to come along? <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Okay, about the 9", I don't think the current owner of the rear knows (or cares) whether or not the center section is cast or nodular. Is there an easy way to tell just by looking at it? Also, would you advise upgrading the 2 "weak points" or will the rear still be pretty strong without the upgrades? From what I can tell, the nodular center section is between $300 and $400. Ouch! What about the billet pinion support? Where might I find that at? Thanks for your help, guys!
Old Nov 13, 2002 | 05:47 PM
Fireball's Avatar
its difficult to tell if its nodular as its still a cast iron with better materials to make it somewhat stronger.
the pinion support should be in the ~100 range or less. make sure its a daytona style for street use or inadequate pinion oiling can occur <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
AFAIK, you can run it sucessfully but the M6 puts some stress on rear components and why do it if it can still break? I've beat the crap out of my 9" and haven't had any problems <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Nov 13, 2002 | 06:47 PM
RAGEman's Avatar
Thanks, Brian. You are quickly moving up my list of heroes! One more question, and another opportunity to move up the list even further: where might I find one of these billet supports? I see a forged aluminum one made by Strange on Summit's website, but no billet ones. Any thoughts?
Old Nov 13, 2002 | 09:15 PM
KTamez's Avatar
The Nodular Cases should be stamped, beit from whatever company they're from. To the best of my knowledge Moser doesn't make a standard Case, only Nodular Iron and Aluminum. FoMoCo actually even has Nodular units floating artound out there that can be identified by the bigass "N" on it. For the cost of a Nodular Iron unit, its a pretty good investment for anyone going 10s or faster, I'd almost suggest the "N" case as a must, no matter the manufacturer.
When we were selling a couple of these things a day we actually outsourced the Center Sections and got 3.25" Bearing Strange units, not so much for the case or other components, but more consistent gear setup.
Hey Brian, where'd you get that Strange case? <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Good luck!
Old Nov 14, 2002 | 07:51 AM
Fireball's Avatar
Hey Kurtis...still working good <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Rage:
I don't know what the part numbers are offhand but I do know I when I bought the rear from Kurtis at the time, the center was built by Randy's Ring and Pinion. The billet pinion support I have is that purple thing shown in the link below <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
http://www.diferentials.com/race-parts.shtml
You can order it from them...
Old Nov 14, 2002 | 08:57 AM
RAGEman's Avatar
Any more experience with this company? They offer lots of ring-and-pinion ratios, but I just need someone to tell me what an awesome company they are before I order all this stuff. Cool website, but has anyone had any experience with them? Kurtis?
Thanks, Brian!
Old Nov 14, 2002 | 10:48 AM
Fireball's Avatar
we've ordered quite a bit of shim kits and whatnot from them. They also set up my 9" center. but if you just get parts there's nothing at all wrong with them <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Nov 18, 2002 | 05:23 PM
RAGEman's Avatar
Update: Per Rob Moser, they use nodular cases in their complete centers.
Old Nov 19, 2002 | 03:01 PM
Thumpy's Avatar
You should be good to go with the 9 inch then!
Sarah is doing well. We're getting ready!
Jeff
Old Nov 19, 2002 | 10:42 PM
justin sutton's Avatar
Moser **** is top notch.I use to have a full moser 9" in an 80 malibu.I really loved that rearend.Wish I had it now.
