Has anyone broke there Mikronite gears yet?
If anyone has broken a Mikronite processed ring and pinion set, we at Crane/Mikronite would like to know about it. We would like to look at the nature of the failure. We also want to be sure that Mikronite process gears are not "lumped together" with other "shiny" surface treated gearsets. The unique features of the Mikronite process is that it imparts "residual compressive stress" into the surface and near-surface substrate (much like shot-peening) while having the highly lustrous finish to reduce friction. No other "shiny finish" treatment strengthens the gearset like the Mikronite process. Additionally, the Mikronite process does not alter the gear tooth profile even when measured to .000001" (yes that number of zeros is correct!).
You might want to check out what Warren Johnson has to say about his experience with Mikronite processed gears: www.mikromaxperformance.com . Additionally, we have seen decidely different quality between different manufacturers of gearsets. The Mikronite process will not make up for quality deficiencies in the base material or machining.
We are very interested in hearing comments from the field. They are important to us to provide continual improvement in our product offerings. Post them or PM me privately. Thanks!
Mark Campbell
VP, Market and Product Development
Crane Cams Inc.
Mark Campbell
Crane Cams Inc.
Originally Posted by LS1crazy01
Mark how well do you think these things will hold up against 4500 rpm launches with drag radials? thanks.
If you check out this post: https://ls1tech.com/forums/gears-axles/764876-crane-mikromax-ring-pinion-gears.html , I explain why we are using Motive Gears. I also make the statement that we are not claiming that a Mikronite processed 7.5” GM ring and pinion will be stronger than a GM 12-bolt or Ford 9-inch: but both of the larger sets will be stronger if they are Mikronite processed. Mikronite processed gears offer an alternative to the enthusiast who is on the margin of breaking their stock gears and needs some extra strength without the hassle of changing entire rear end assemblies.
As for your question; if your vehicle is set up to launch smoothly without wheel hop, the Mikronite gears will last considerably longer than the stock gears, but I would be foolish to make a statement of how long when there are so many unknowns about your vehicle. 4500RPM launches on drag radials is pretty abusive! We have had several F-bodies (stick and automatic) that were breaking ring and pinions after anywhere from 10 to 20 passes and now have over 80 passes on them and they still look good. We have had Late Model and Modified circle track cars that changed ring and pinions twice a year and quick change gears annually who are now running their third full season on the same ring and pinion and quick change sets (three years on the same gears and they still look good!). I know this doesn’t answer your question, but I hope it helps. Keep in mind that the whole suspension must be set up properly or no ring and pinion will last.
everytime you dump the clutch, its still going to be a gamble.
will it be stronger? yes. no doubt.
will it last longer? depends on alot. if you're exceeding the breaking point of the stocker (and you probably are) AND you're under the higher breaking point of the process.. yes, it will last longer.
but if you're dumping it hard and hooking... you're probably exceeding the breaking point of ANY 10bolt, regardless of gears.
also, i should note, that the gears are not the main breaking point of 10bolts... the posi also likes to blow apart... keep the gears and posi together, and you still can flex the case enough to hurt the gears... or snap an axle.. etc.... the gears are not the only weak point of the rear.
that said... no one can guarantee anything.
14 Second Truck Club
I searched this first but its not working. But I was wondering if anyone had broke one of these in there 10 bolts yet.
Yes with the 10 bolt you are taking a gamble anyways. A 4500 RPM launch and sticky tires especially if you hook right off the line... my bets are if the gears hold you more than likely will blow out the diff and or axles. I am saving for a 12 bolt once my 10 bolt decides to take a puke, its my DD so I don't really beat on it too much as well as no powershifting lol.
