Moser 12 bolt question
Old Sep 1, 2007 | 11:30 AM
SimplistikTA's Avatar
Default Moser 12 bolt question
What all do I need to ensure a complete, direct swap? I just want to make sure I bought everything before I tear my car apart. Thanks in advance!
Old Sep 3, 2007 | 08:48 AM
Anybody???
Old Sep 3, 2007 | 09:20 AM
keliente's Avatar
https://ls1tech.com/forums/showthrea...nstall+12+bolt
really the only thing you need is gear lube and 3" exhaust clamps for your rear sway bar.
Old Sep 3, 2007 | 09:47 AM
01Z28M6's Avatar
Sorry SimplistikTA for butting in - this has been the question on my mind. You mean the brakes, TC, ABS, relucter et al. need nothing more/changed?
I'm thinking this is my next modification....
Old Sep 5, 2007 | 05:13 AM
EPP's Avatar
EPP
http://www.exoticperformanceplus.com....html?item=146
Everythying that you need can be found here. Bob
Old Sep 5, 2007 | 02:55 PM
Okay I already got the sway bar mounts from Thunder Racing(where I bought everything) along with the exiter rings for my speed sensors. They were saying something about getting a custom driveshaft made or using a different universal joint than stock. Something about the yoke on the pinion being different. Does anybody know anything about this? Mine has the 33 spline axles with the modified Eaton posi. I wouldn't think that that would change anything. Anybody else get theirs from Thunder Racing? If so was it a straight forward install?
Old Sep 5, 2007 | 04:26 PM
DopdBrd's Avatar
subscribing
Old Sep 5, 2007 | 06:18 PM
keliente's Avatar
Sorry, forgot to mention the universal joint. You would need a conversion u-joint to fit the 1350 yoke if you've got a stock driveshaft. Napa part number - 240-0447.
Old Sep 6, 2007 | 05:01 AM
Cool thanks. I guess I have everything then.
