How much HP / tenths do you you lose but swapping to 12 bolt or 9inch ?
Old 09-24-2007, 01:17 AM
jfman's Avatar
Default How much HP / tenths do you you lose but swapping to 12 bolt or 9inch ?
How much HP are you expected to lose when you switch to a 9inch or a 12 bolt rear end ?
I'm guessing since the rear end in heavier, youre gonna lose some hp on the dyno and run a few tenths higher in the 1320 ?
Old 09-24-2007, 01:37 AM
GreenBlood's Avatar
dyno numbers are usually meaningless, it varies car by car, the gears, m6 or stalled auto, etc...as for dyno times, you should be able to run better...with a stronger rear, you can launch the car better than if you pussyfoot around trying to extend the life of your 10 bolt... if you can cut better 60ft times, hopefully you can pull a better quarter...
Old 09-24-2007, 10:23 PM
chicane's Avatar
Its going to be Infinitesimal.
Why is it that everyone splits hairs over this very question ?? Its not going to make you any faster... or any slower for that matter. If anything... a 9 will be slower due to it being more inefficient from the pinion being further off centerline and it being a little heavier.
Old 09-24-2007, 10:27 PM
Sartobuilt's Avatar
I lost .2 in the 1/4 mi.
Old 09-25-2007, 07:48 AM
LS1crazy01's Avatar
Well I would think for me going from a 10 bolt on nittos with stock 3.42 to a 12 bolt or a 9 inch with 4.10's and some mickey thomsons would shave a couple tenths not add them.
Old 09-25-2007, 12:29 PM
hpjunky98's Avatar
lower your gear ratio to compensate for the added weight
Old 09-25-2007, 12:35 PM
keliente's Avatar
I agree. Not to mention you can leave a LOT harder with your new rear, which evens out the fact that you added a few pounds.
Old 09-26-2007, 12:59 PM
chicane's Avatar
Yup yup.
The air temperature and local air density changes will effect your times more than the addition of a 9" or 12bolt differential.
.2 is more likely related to the driver than anything else.
Old 09-26-2007, 05:23 PM
Big Bird WS6's Avatar
common rule i have heard is going form stock to ford 9. it is 9hp per 100hp ( 500 rwhp stock = 455rwhp ford 9 ) and a 60 is like 12 hp per 100hp
Old 09-26-2007, 07:34 PM
Wino's Avatar
I killed my 10 bolt on the run right after my first 12.9; car was stock heads/cam then. Got the 9" in, got used to it, pinion set right, etc. and ended up with a 12.4. It helps when you can leave the line at whatever RPM you want without having to worry about the rear end breaking.
I'll admit, I am really curious what kind of dyno #s the car would put down now with a 10 bolt.
Old 09-26-2007, 08:52 PM
IROC403's Avatar
no time change at all, I leave harder now, that makes up 4 any loss
