beef up the 10 bolt?
http://www.geocities.com/duragizer444/install.html
Good luck with whatever you decide!
-Jeff
So I might as well do it now, use it for a while and save fro the upgrade. Plus, after talking to some guys at the LSX shootout, making great power and hitting 10's and 11's on stock rears, it is possible.
I am looking at the auburn thoughfor the carrier, seems like they have a higher recommend the the Eaton, however, not buying it tomorrow, so I am still researching, listening and reading. 3.73's for sure, maybe new axles and I am leaning towards the solid spacer vice the crush, so it takes longer to set up, seems to be the prefered method I have read so far. (NO I did not take a poll!
)Just my thoughts.......
I opted to spend a couple hundred bucks instead to make a 10 bolt be able to withstand the beating i put it through. And for the record, it has taken it pretty well.
BTW.. good luck with the donations.. I have not gotten any yet either!
-Jeff
Good luck with whatever you choose!
-Jeff
People need to understand there is more uses to a car than ONLY drag racing. For example, mine is being turned into a autocross car. There are plenty of people i know around town that enjoy just cruising on the streets with their 400hp cars. They also, would have no use for a 9" rear end, as they would not get traction anyways, unless they went with some M/T streets. but since they drive ALL the time, they dont have them, as they would be worn out every 2000 miles.
Depends on what you plan on doing with YOUR car, not what other people think you do with your car. If you go to the track every friday and drag it, then you would be better going with a guaranteed strong rear end (9" or 12bolt). If you do pretty much anything other than that, then a beefed up 10-bolt should suffice for the purpose.
-Jeff
You don't.
It seems like too easy of an answer, but it holds true. The 10 bolt will always be limited by the fact that it is simply smaller than a 12 bolt, 9 inch, or Dana 60. Smaller = weaker.
Besides replacing the ring & pinion and bearings, adding aftermarket parts such as stronger axles only seems to be a waste of money. The minute you fix one thing, another will break. Rear end installs can be costly if you are not doing the labor yourself - it adds up quick. Don't be the guy who says he can't afford a 12 bolt, but has spent $1500 dumping money into his 10 bolt.
-Jeff
Hell of a job dude. I'm with you on this one . My 02 Z/28 is an A4 also and while I go to the strip once or twice a year my thang is street cruising/racing, so I ain't puttin up with no loud *** gear whine or a howlin rear end.My ride is bolt-ons & will stay that way since its a Vert. By the way, does any body know if my 02 has a series 2 or 3 gear case & is it a eaton or torsen & which is better & why ?
I beg to disagree. The factory 10-bolt is so ****** weak a Chevy Cavalier could make it whine & howl like a banshee with a lead-foot teenager at the wheel in less than a week!
