Aftermarket Diff cover??
Old Nov 21, 2007 | 10:25 AM
tording99Z28's Avatar
Default Aftermarket Diff cover??
So i am doing a rear end swap into my A4 Z28 from a M6 car. While I am at I want to upgrade the diff cover to a stronger one that will help give a little strength to the rear end. What is a good one that is not too terribly expensive and where can I get it? Thanks in advance.
Old Nov 23, 2007 | 04:56 AM
96LT1355Z28's Avatar
Trick Flow, T/A, Summit, just make sure it has the support studs in the center to preload the bearing caps. Summit Racing has them for around $150. I don't know if they will really make a 10 bolt any stronger, but they couldn't make it any weaker!
Old Nov 23, 2007 | 05:02 AM
Transamman25's Avatar
I love my T/A cover and if purchased through Herron Performance ... they are ussually 140 ish unless purchased with a GP in which case ... cheaper --- He always offers free shipping and is still cheapest in town ... Youll never hear a cross word from anyone about him --- not to mention he has one fast F-body !!
Old Nov 23, 2007 | 09:04 PM
BriancWS6's Avatar
I wouldn't waste the money. Set that aside for a 9in or 12 bolt. Your 10 bolt will live for a LONG time in that a4.
Old Nov 24, 2007 | 05:23 PM
Yeah I have heard that they actually live for quite a while in an A4 cars but I figured while I am doing the swap and will have the cover off anyway to pull the axles I might as well put a new girdle cover on while I am at it? You don't think it would be worth it at all?
Old Nov 25, 2007 | 12:21 PM
BriancWS6's Avatar
What HP/TQ level do you plan to stop at? My previous A4 ran LOW 11s with an un-touched stock rear. Maybe if you were not gonna push it too awful hard, it would help enough to keep it together. But if you ever plan to make some decent power, the money could be better spent towards a rear that could take the abuse.
Old Nov 25, 2007 | 04:59 PM
drews94z-28's Avatar
I'd sell you the one off my ten bolt for a good price...my car came with one I think it was part of the auburn option...ill get some pics if your interested.
Thought I'd also add mine is aluminum and is an AAM one.
Old Nov 25, 2007 | 05:25 PM
I would eventually like to see some 10's in the car but my goal for the next year is a 11.5 car on spray that can be daily driven. Based on what you have said I guess I for sure wouldn't need a girdled cover so I will just keep my eyes open for a good deal and if I find one then I will pick it up. Thanks
Old Nov 25, 2007 | 07:26 PM
BriancWS6's Avatar
No problem man, glad to help. Good luck with your setup.
Old Nov 26, 2007 | 12:25 PM
dailydriver's Avatar
The biggest advantage of an aftermarket cover is that you can drain the gear oil without the hassle of resealing the stock steel cover. More frequent gear oil changes could possibly help the 10 bolt live longer (and stay quieter), especially in an A4 application.
Contrary to some of the opinions on here, gear oil is NOT a 'permanent fill' fluid, and it most definitely does shear down with use, time and heat, especially in a performance, high power/shock loaded situation.
Old Nov 26, 2007 | 12:49 PM
omcar's Avatar
I have an LPW and like it as it stiffens up the rear and makes draining the fluid easier.
Old Nov 26, 2007 | 01:19 PM
teke184's Avatar
while you have the rear apart...i would at least replace the bearing cap bolts with studs...
inexpensive insurance.
my 10bolt is holding up to some hard shifts with 400rwhp....a stage 4 clutch...and 315 DRs.
i think the girdle is helping some....
