Will any 3.42 work?
Old Jun 23, 2003 | 12:17 AM
99PTA's Avatar
Default Will any 3.42 work?
I'm goin to buy a gear from this guy but its just a ring and pinion. Its off his 2000 SS and it has 6000 miles on it. He got a bigger gear thats y he is selling....do i need anything else for the install?? i have automatic......if his was a standard can it still be used in my car??
Old Jun 23, 2003 | 12:20 AM
BIGBOS's Avatar
Default Re: Will any 3.42 work?
It should be fine, your auto has a 3.23, is the guy you are buying off of 6-speed or auto, 6-speeds have 3.42's, you don't want to swap with an auto because it won't give you any gains...you would be swapping for the same gear...
Old Jun 23, 2003 | 12:24 AM
99PTA's Avatar
No i have 2.73s (GU2) and i sent a e-mail that asked him if he was a4 or m6 waitin for reply
ok i got reply.....it was a 6-speed
Old Jun 23, 2003 | 12:32 AM
BIGBOS's Avatar
ok, so they will be 3.42's so you will be fine...thats a nice gear increase...
Old Jun 23, 2003 | 12:39 AM
99PTA's Avatar
Thanx....im hoping that this gear increase will help me drop into the mid 12s (with all my other things fixed....see the sig)
Old Jun 23, 2003 | 12:42 AM
BIGBOS's Avatar
That gear should put you there no problem, get some headers and get into the low 12's...
Old Jun 23, 2003 | 02:14 AM
99PTA's Avatar
Yea thats the plan....headers next!
Let me ask this....will i need an install kit, crush sleeve, and are there any other parts that should be replaced??
What do all these parts run??
Old Jun 23, 2003 | 11:51 AM
Fast Eddie's 02 T/A vert.'s Avatar
My 2.73s were a thick gear.Luckily the 3.42s i purchased were a thick gear as well.I originally planned on 3.23s but it was a thin gear and wouldn't fit my carrier.I really like the 3.42s,what a difference from 2.73s.
Good luck.
Old Jun 23, 2003 | 01:23 PM
99PTA's Avatar
So what happens if the gear i buy is a thin gear?
Old Jun 23, 2003 | 02:16 PM
Then you will be in the position i was in.You would have to change the carrier at about $400.+,or find a thick gear.
I'm not an expert by any means,i'm just glad mine is back together and driving again w/3.42s.
Good luck.
Old Jun 23, 2003 | 03:28 PM
99PTA's Avatar
So....how will i know??? i have never seen a comparison. Its a really good deal....and how come now one else has brought this up about thick or thin.
OK i just called MTI and talked to wayne.........and he said that if the car that i'm buying the gear from is a 2000 SS his gear will be thin. Mine on the other hand is a GU2 and and needs a thick gear.
Old Jun 23, 2003 | 06:05 PM
99PTA's Avatar
The guy i'm lookin to buy from sent me this e-mail. after i told him that i needed a thick gear and the his was thin (told by MTI)
"Yes, I am aware of that. Auto's come with 2.73 and 6 speeds come with 3.42s. I had 3.42s stock and switched them out for 3.73s and then again for 4.10s
They will fit fine."
Old Jun 23, 2003 | 08:29 PM
nuzee's Avatar
The 2.73 gears use a 2-series differential carrier. The 3.23, 3.42, & 3.73 gears use a 3-series carrier. To put a 3-series gear on a 2-series carrier, you have to either use a spacer ring (not recommended) or use a "thick" aftermarket gear made especially for this swap. You could also replace the 2-series carrier with a 3-series and use the 3.42 gears. The later option is what I'm going to be doing soon.
Also, you might have to get a new reluctor ring if you have a 3 channel ABS setup. Somebody else can better explain that, since I don't have the 3 channel setup.
Hope this helps
Old Jun 24, 2003 | 07:17 AM
squirrels's Avatar
If you use a "thick" gear, from what I've heard, the spot at which the gears engage is not ideal for durability.
You can get a 3-series "take off" carrier from SLP or another vendor for like $99. You're going to need it if you're buying just the ring-and-pinion off your friend. Those 3.42s were designed to work with a 3-series carrier.
