what gears?
My question is what gears do I need to make my combo of cam and wheel size work for my advantage? The car will remain a cam only car for a long time. I am open to any and all suggestions.
sammyb
http://www.f-body.org/gears/ You can enter in the combo here. and play with the info, enter max rpm as where you want to shift at, over reving the motor just because it can make it to the finish line without hitting the rev limit doesn't mean it will go faster. Ideally you'll want to hit the finish line in 4th gear with your shift light just turning on.
Depends on the cam, if you go with something you rev to 6700 then you may go with a 4.30 gear, I wouldn't go 4.56 without a taller tire.
I have a set of 3.90's any i have no complaints at all. They are SO quiet unlike my 3.73's in my v6 camaro which drove me nuts.
Also, my car is a DD and 3.73's wouldnt have made much of a difference and 4.10's would have been overkill IMHO. I feel I have the best of both worlds.
I don't know how tall of tire you are planning on using, but with my stock rims/tires I barely top out 4th in the quarter mile.
Good luck!
I liked the 4.10's the best, 4.56 I ran out of gear in the 1/4.
My next gear set will be a 4.30 or 4.56 gear but I will be running a 30 or 31" tire.
