Midwest Chassis & Performance fab rearends... new pics
#2086
Thats just how it is they are a pain sometimes. dont grind the holes bigger. Just tweak them where you need them if you have to. I got the 3rd member set on the studs and had to beat it on with a rubber mallet and push and finally went on. This is the normal procedure I used on the 9 inchs I have installed. it will go on.
#2087
#2092
yeah like they said,just get the studs as close as you can,and then tap it down.I had to pull mine apart last week,i taped a razor blade between the 3rd member and housing,then taped in a metal putty knife,then used the thin pry bar and worked it back off.Got it off in about 20 mins while it was still in the car,its really not to bad.
#2095
Jason or Eric - have a quick question on my MWC. On the spring perches, what is the inner diameter of the hole? My 2 job work schedule is crazy this week and I don't have any time to jack up car, remove wheel and spring, and measure it. I am trying to get a custom coilover setup.
