backing plate question
Old Dec 23, 2007 | 09:16 PM
pushinfreight's Avatar
Default backing plate question
The part number in the general maint part number list does not pull at gmparts direct. Does anyone know what the current part number is for the backing plate left and right side for an 01 TA with tcs/abs?
Old Dec 24, 2007 | 10:38 AM
ssvert99's Avatar
LS1Tech Premium Sponsor
you need backing plates and the caliper mounts? there are two pieces per side on the 98-02 rears
Old Dec 24, 2007 | 12:01 PM
just the backing plates, need to get them pressed on while the rear is being assembled so that I dont have to worry about getting mine taken off and then reinstalled.
Old Dec 24, 2007 | 12:54 PM
RA4926's Avatar
10434796 & 10434797 Brake backing plates (whole assembly w/ ebrake)
thats all i could find
Old Dec 24, 2007 | 07:16 PM
ssvert99's Avatar
there are 2 seperate pieces on each side of the 98-02 brakes that are required for a rearend swap with the 9 inch type pressed on axle bearings. the sheetmetal "backing plate" is the part that holds the e-brake assy, and the cast steel heavy part is the caliper mount. they come seperately and are available that way. Strange gets 250.00 for the parts new when ordering a rearend.
Old Dec 24, 2007 | 11:04 PM
ls14jay's Avatar
Plates are under rear suspension/brake components.
It lists them as caliper mounts, doesn't list backing plates,but has illistrations.
I just ordered a couple here locally,paid about the same as if hey were shipped from gmparts.Hope I ordered the right stuff to put my 12 bolt in. I was just going to take the plates and rear to a shop to have them pressed on.Am I missing something? I didn't see any dust covers in the illistration.
Jay
Old Dec 26, 2007 | 08:59 AM
ls14jay's Avatar
Just picked up mine at the chevy dealer.
Part numbers for 98 without tcs,plate and dust cover come all one piece.
10444625
10444626
Might be different with TCS, not sure.
Not sure which is left or right.
List price 124.39 each, paid 85.00 each at dealer.Somehow found a guy who sells parts for net pricing..
Jay
Old Feb 2, 2013 | 10:16 AM
Lazzarus's Avatar
Bumping this thread from the grave, but, this saved my ***. Thanks, guys.
Old Aug 25, 2013 | 09:17 AM
89ROC-Z's Avatar
What all comes with those part numbers? The caliper mounting bracket and the dust cover? How about the parking brake shoes?
Thanks
Old Aug 26, 2013 | 10:43 AM
ssvert99's Avatar
It comes with everything needed... Plate, shield, lever, boot, shoe, adjuster, etc.
I have them in stock.
