Breaking in a 9" Moser rear end...
That's BS! I would make a 15 minute trip to get something to eat after you get done with your test drive and then bring it back and let the car cool for 5-6 hours. Then do it one more time. I didnt try to get on it for the first 100 miles just to let a few more heat cycles naturally go through. To be honest, I launched mine 125 miles after and it was the ****! Just understand you just added alot more weight to the rear so I hope you got gears or plan on having 410-450 hsp.
I ordered the 4.11 gears in it and am running probably 330-350 rwhp with my setup. In the future i will end up putting a blown 383 stroker in it though. Will it still pull really good? With the 10 bolt it blew the tires off in 1st and second gear all the way to redline.
I highly doubt you are going to notice the weight difference, it just isn't that much of an increase.
We advise putting 500 miles on the rear before going wide open throttle, to fully allow the gears to break in. Understandably most people just can't wait this long... lol Bob
Yes, breakin is necessary. Here is a link to our site with appropriate breakin information...
http://www.jawsgear.com/tech_faq.php
Jeff
Jeff
NO! You need a baseline tune and the motor should have atleast a two heat cycles through it especially with new valvesprings. Trans kinda just a heat cycle thing and letting it get fluid though it. I would never WOT the car with a new motor before atleast 1 heat cycle. I would hate to see it wreak havoc on you valvespring.
Ok, besides a couple heat cycles............ I obviously meant that and should have stated that. What I meant was, after a couple heat cycles, etc and a base tune to get her running. The car is than more or less ready for a WOT tune, I know its a long process until its finally broke in but WOT is needed to seat the rings correctly and more so in FI engines. If there is some beating on the car than obviously the trans and rear will be taking it too is why I only asked. To break in everything properly all at the same time after the intial base tune and the car ready for the road.
