Is .003 of backlash too tight for 4.10's in a 10 bolt?
OK so I am putting Motive 4.10's in my stock 10-bolt rear in my 98 TA as we speak. This is a true 4.10 with a 10 tooth pinion. I replaced all the bearings and seals. Right now I've got a good contact pattern and about .003 of backlash. It's turns smooth as glass, but I know it's supposed to be minimum of .008 backlash per the instructions. My question is: What will happen if I run it at .003 instead of loosening it up to .008? What is the best recommended setting for QUIETEST operation? I dont care about strength, I want them QUIET. Thanks for your help!
![The Pimp](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_pimp.gif)
i thought motives were 0.006 - 0.008
AAM 0.004 - 0.006
Richmond 0.006 - 0.010
those are just what i have heard the manufcture suggest, i have also heard that rule of thumb was 0.001 for every inch of diamter the ring gear is, i believe chicane suggested that. As for running them too tight, im not exactly sure what dammage would occure
AAM 0.004 - 0.006
I just put a set of Motives in my car this past weekend. The recommended backlash with the gear was .008 to .012. Ideally you want in the dead center of that. The closest I could get was .008. I have put about 100 miles on the gear. It whined a bit at first but the whine is getting quieter and is almost gone. I was told this is because my backlash is loosening up a little.
My Motive 3.90's called for 0.008" - 0.012".
IMO, a gear is a gear is a gear. They're all made of steel, likely of similar/same physical properties.
Since Richmond calls/allows for the tightest setting (0.004") then I'd say that's probably the limit. Keep in mind, with a low ratio such as a 4.10, they're going to be spinning really fast inside that diff. They're going to build a lot more heat (I would assume
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
Go back to the drawing board!!
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
![Mr. Cool](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cool.gif)
... and a guy at a gear/driveline shop told me he always aims for ~.006" - .008".
Realistically? I think Richmond probably has the best advice. 0.008" +/- 0.004"
Although for further confusion into the mix ...
... without looking at the paperwork, I believe Richmond calls for something like .020" - .022" for circle track setups ... basically, a setup that is going to be run long and hard. Completely opposite from drag racing.
SO, what do we gather from all this?! Tight for drag racing, loose for roundy-round racing, and probably somewhere in the middle for street/strip
