Auburn Diff. with 3.73 gears.....
Old Aug 2, 2003 | 11:56 PM
Michael Ozorowsky's Avatar
Default Auburn Diff. with 3.73 gears.....
Topic says it all. Broke the Zexel a few years back, replaced with auburn, now its time for me to change diff. fluid. What kinda fluid? Synthetic or what? This is a first fluid change for me. Thx.
Old Aug 3, 2003 | 03:52 AM
pekkaz's Avatar
Default Re: Auburn Diff. with 3.73 gears.....
Auburn does not recommend synthetic, clutches probably don't like it 100%. I've used Valvoline and Mobil non-synthetics with the same combo. And I change the fluid quite often ...
Old Aug 4, 2003 | 09:17 PM
destroyerSS's Avatar
use a good 80/90w gear oil With ford posi addative and you should have no problems.
Old Aug 5, 2003 | 11:23 AM
hodiec's Avatar
How would Royal Purple work,
I have an Auburn also,
Or should I stick to Dino
Old Aug 17, 2003 | 08:54 AM
Coastal 80W90. Says it's for Limited Slip Differentials. Will that work for me? Thanks.
Old Aug 18, 2003 | 12:36 PM
ttt?
Old Aug 18, 2003 | 11:04 PM
Slowhawk's Avatar
LS1Tech Sponsor
It will work.I'd prefer 75w140 non synthetic with GM additive.
Old Aug 19, 2003 | 09:11 AM
SSCamaro99_3's Avatar
My pinion seal gave up, so I am doing a fluid change because not much is left. What are the advantages/disadvantages to the heavyweight fluid in the rear end.
