RaTech Rear end Rebuild to fix WAWAWA sound?
Ok so i was reading some threads because i have a droning wawawa sound that gets louder and louder the faster i go.
I was readin this thread and am thinkin about getting a rebuild kit since i cant afford a 12 bolt or entire new rearend.
https://ls1tech.com/forums/showthrea...ighlight=noise
I found this ratech kit for gear installs but it includes all kinds of other pieces including carrier and wheel bearings.
85-3001K Ratech Deluxe Gear Install Kit for GM 7.5" 10 Bolt on thunderracing for $122. Think that would fix my problem?
Dont buy ratech. Thier shims are really cheap and you'll end up having to buy more to get them to fit right. Buy Yukons and you'll really be happy. The quality is ALOT better and you dont usually break thier parts to install them
Well i really dont know anything about rear ends, is replacing the bearings something I can do at home? If i took it to a shop how much could i expect to pay in labor to have them rebuild the rear?
If you have a press and puller you can change the bearings at home. IF you do not I would reccomend taking it to a shop that does differentials for a living. We carry a complete Master Timken Kit and Axle Bearing Kits. Give me a call or pm me and I will be happy to get you some pricing.
Jeff
Jeff
So it turns out the vibration i have at high speeds is because one of my ujoints is totally worn out, they said it has a lot of play in it. The wawawa sound is from the bearings, there was lots of metal shavings on the magnet and supposedly the vibrations from the ujoint probably caused the bearings to go bad is what im being told.
