Clearancing for a Moser 9"
Old Jun 13, 2008 | 02:07 PM
BadgeZ28's Avatar
Default Clearancing for a Moser 9"
I am running a stock torque arm. After centering up the rear end with the adjustable panhard bar, I could see clearance problems at the side of the torque arm. I took a bar and pressed the floor pan out of the way on the one side. I am still getting a bottoming when I hit a bump. Car is lowered with proline springs. Is this normal for this install? Thanks
Old Jun 13, 2008 | 02:33 PM
BMR Tech2's Avatar
LS1Tech Premium Sponsor
Talking
Hello, yes this is normal when using a 9" because of the width of the center chunk the bracket is not in the same spot as it is on a factory rear. You can massage the floor pan a little. If you have any other questions please give me a call.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old Jun 13, 2008 | 06:14 PM
bigsticksupra's Avatar
The upper bolt on the cast moser torque arm bracket will hit the transmission tunnel by the gas tank
Old Jun 13, 2008 | 06:42 PM
BadgeZ28's Avatar
Ok, I didn't see any clearance problem there but will look again. There should be some marks from my bottoming out. Thanks
Old Jun 13, 2008 | 06:44 PM
sixpack_2_go's Avatar
ya, my car isn't lowered and the torque arm mount bolt is really close to hittin the floor pan in the tunnel. i want to lower my car so i guess im just gonna have to push my floor up too. oh well, then it will match my other side pan where my driveshaft broke and pushed the floor up...that sucked
Old Jun 13, 2008 | 06:54 PM
EPP's Avatar
EPP
We take the pry bar and gently add a little clearance up there as well. Bob
Old Jun 13, 2008 | 08:59 PM
CW00BlackTA's Avatar
Gently? I took a BFH and beat the hell out of mine to get it to stop hitting. I'm lowered on Strano's.
Old Jun 14, 2008 | 06:10 AM
EPP's Avatar
EPP
Thumbs up
Lowered cars do need a little more persuasion... Bob
Old Jun 14, 2008 | 08:50 AM
AFASTYZFR1's Avatar
I let mine self clearance and didn't work out to well....lol........it is fixed now and has plenty of clearance and fits under carpet
Old Jun 14, 2008 | 09:53 AM
BadgeZ28's Avatar
