3.73s and auto tranny question
Old 07-26-2008, 07:58 PM
nemss1's Avatar
Question 3.73s and auto tranny question
if i installed 3.73s wit my suto tranny, would it throw anything else off besides the speedometer? would it still shift normal?
Old 07-26-2008, 09:45 PM
lt1noob's Avatar
yes, it should. just need the speedo recalibrated.
Old 07-26-2008, 10:28 PM
nemss1's Avatar
sweet! so i can throw in the 3.73s and drive it witout a tune? i wont get a tune for awhile. the tune i want is $350
Old 07-28-2008, 12:38 PM
andrew69_04's Avatar
wont the shift table need to be recalibrated for the different gears?
I saw a camaro once set up for 3.42's and had 3.23's in it. had problems hitting the rev limiter between shifts.
Old 07-28-2008, 01:41 PM
BIG_MIKE2005's Avatar
I wouldn't do that. I'd wait & get the gears installed the day before your tune is scheduled. I'd imagine there is more to be done than just the speedo when on a auto car.
Old 07-28-2008, 08:08 PM
sixvi6-camaro's Avatar
what needs to be changed is the spedo calibration, TCC tables, Part throttle shift tables, and full throttle shift tables. You can drive the car with no problems and it won't hurt anything though but It will not shift correctly at WOT, shift harder at part throttle and will put miles on the car faster than it should.
Old 07-28-2008, 08:34 PM
IROC403's Avatar
you can buy a used crappy hand held tuner cheap to calibrate for gears for now,
then just sell it later. I did that and sold it for what i paid for it after i got it tuned .
Old 07-28-2008, 09:01 PM
boola1341's Avatar
Are you for real about putting miles on the car faster?
Old 07-28-2008, 09:31 PM
1996firebirdformula's Avatar
And it will mess up your gas milage LOL! 3.23s are already bad enough for highway speeds For A4. im at over 2.2k at 75 mph.
M6 with 3.73s just laugh at rpms
Old 07-28-2008, 09:32 PM
Elliott's94Z's Avatar
That's the stupidest thing I have ever heard. My 3.73 on the hwy hardly change much at all. Yeah, it's worse but not a huge change. I got sweet mileage with my 3.23 on the hwy.
Old 07-28-2008, 09:41 PM
2200 at 74 mph with 3.23s
2500 at 73 mph with 3.73s
1800 at 74 mph with M6 3.73s
http://www.f-body.org/gears/
Old 07-28-2008, 11:29 PM
ok so you are giving me info I already know..lol So what are you getting at? Not trying to be a douche..
Old 07-28-2008, 11:57 PM
Yes it will.. because the pcm will think the car has a 3.23 or 2.73 or whatever gear but in reality you will have a 3.73. that difference in the actual gear vs what the PCM thinks you have will cause the spedo to run faster than your actual speed and run the odometer faster. example... for every 100 actual miles you drive it will show as 110 miles.
Old 07-29-2008, 12:01 AM
GT Griller's Avatar
Werd...my highway gas milege didnt change much either...maybe 1 or 2 MPG.
True...i ran mine untuned for a year and when i was going 70 the car showed 80 so the odometer thought i was traveling further.
Old 07-29-2008, 09:54 AM
^^exactly
