rear end making noise
ok so heres my problem every time i go around a corner above 20 mph and let off teh gas as i turn i hear a knocking/vibrating/funny sounding noise ne one kow what it could be
Is it from the front or the rear?? Pretty vague...need more info to really give you any good answer. But you could start by checking bolts/nuts, basically any moving part for wear or failure.
my bad its coming from teh rear everythings tight and the struts and shicks are brand new im kinda worried its the locking mechanism in the diff
it doesnt sound like nails cutting through paper like some of those articles say it sounds like a knocking noise whenevr im turning and let off the gas ne other ideas guys
not that i can see i mean we replaced teh outer wheel bearings so im not quite sure what it could be no leaks from what i can see how do i check the backlash
