Suggestions for Gen5 Camaro
#61
FWIW, I had 4.33's and loved them for the 300-400 miles they lasted. I'm done pissing money away on the stock differential. Going to place an order for the 9" within the next month and it's going to have a 4.30 gear.
#62
If you have a manual the 3.91 gears are the best for the quarter mile. AAM makes better gears than Richmond, even if Richmond has improved I would let someone else find out if it was true. Most like 4.11's for the street. That could be because they never tried the 3.91's.
#63
Let me know how this goes cause I'd like 2 upgrade to a 9 with 430
#64
#65
I hope that it will get a lil faster yet as it only has 5k miles on it
I bought it for the wife and kids to have fun with and a excuse for me to have a fast car ... Lol. Didn't think it would b this fast
I want to take some weight out of it. Stuff I can unbolt and put back on
What can I take off? Anyone know?
Seats.. Etc
The trick to running a good time in these cars is all in the 60ft
#66
#68
I knew you were talking about a six speed manual, but with a 3.91 gear that puts you in 4th gear as you cross the 1/4mi mark, does it not? I'm just a little confused as to why you believe a 3.91 is better than a 4.11 or 4.33 for the strip. I'm not being critical, just inquiring.
#69
#70
Both are easy to install. The bottle washer is really fast. Let them know what kind of air intake you have because there are adapters for the CAI intake and there might be some for others.
The scoop is a little more difficult, you have to jack the car up and cut a small piece off the shroud by the radiator with a die grinder or dremmel. I didn't believe the BS about the scoop when I heard about it so I built one myself and it does work well. Its like ram air, the faster you go the more HP you gain. Here is a pic of the one I built. Its made out of Aluminum so it isn't as heavy as it looks.
#71
#72
I have an Auto, the only Gen 5 car I have driven with a manual is a friend of mines 800rwhp monster. He had 4.11's and recently went to 3.91's, the track doesn't open up for a few months so I can't tell you the time difference but he's not having the problems with traction as much as he did with the 4.11's
Gear ratio and rwhp go hand in hand. What rwhp are you at right now? Another thing that's a factor is what kind of forced induction you have. If you have a whipple or maggie you will like the 3.91's more than the 4.11's for the quarter mile.
As far as what gear I was in with his car, I was well into 6 gear with 4.11s (not my car so I didn't want to go too high on the rpms) so I can't see the 3.91's making that big a difference there. It was traction that made him go to the 3.91's, he has a maggie for force air and they give punch right from the start. He is having a hard time getting traction when he launches even with suspension mods and Nitto NT05'R'S
#73
#75
I think it has something to do with the VVT system. Most of the time when someone with a automatic buys a VMAX they either don't like it or don't notice any difference.
The VVT system reads the throttle body to anticipate where the cam should be. The system must be calibrated to that throttle body and when you put a different throttle body on it you throw the system off. That's my theory, I have no proof
#76
#77
Let me know when u get it installed
I'd like to take a ride
If u still have stock size tires 28.5 in tall
Your 4.56 will be around a 4.26 gear
When u go to the track
If u don't have. Sticky tire u can us my stockers with m/t dr
#78
Yup, the taller tire is why I went ahead with the 4.56. Thanks for the offer on the m/t's, I may take you up on that. What size are they?
#79
same height as stock
Lil 2 wide for stock rim but ther ok
The stock size is actually shorter and I diidnt want car to set lower in rear than the front
