Thermostat Change
Only reason to get a lower thermo is for heads cam intake and only a 180 160 is to low. For my 650 429 ls3 i have lower fan temps, bigger radiator, and a 180 thermo and it stays at 190 ish no lower no higher runs great.
thanks guys
I find this interesting. So, excuse my ignorance on the details pertaining about the LS3, how much different is internally the LS3 when compared to the LS1? The Ls1 benefits from a lower T-stat.
#33
LS1Tech Co-Founder
I'd rather run a car at 180F then 200F.
Had the 160 stat again about all things the dribbler SBC in my '51 Mercury. I put one in there, and a friend swore up and down it would run too cold. Coldest I ever saw was 175 when it was 27F out and I was going 70mph on the highway.
I'd personally have the fans on sooner and have the car running 180F ish... With the LS1's they were getting well over 200F, I think we used to see 210F.
#34
Even with turning the fans on sooner, the t stat is still going to regulate the heat higher. Esp if you like hearing the fans come on full blast when the stock operating temp hits 190 because keeping an engine cooler helps. If it didnt, NONE of the tuners would turn the fans on earlier.
Most people that say keep the stock stat but turn the fans on sooner just contradict themselves.
Too many people believe that the spaghetti tells them.....
What are their ideas on running an oil cooler? You realize that its not just to keep the oil at a certain temp right? Oil also pulls heat from the engine. By this fact alone, all Camaro5 guys with V8s need to remove those as they will not allow the pistons to heat up to their so called desired temp either!!!!!!
C5 breeds a huge amount of ignorance.
#35
#37
The ls motor requires a temp of about 210 to burn off all the vapors that get in the crankcase. Look at your temp gauge and notice that straight up is 210.
I tried a 160 ts and my car ran rich. I tried the cut off the front of the ts to have free flowing. After going back to the stock ts my car ran better and cooler.
#38
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
#39
#40
