12.80 @ 109.78 bone stock, tuned A6
I havn't seen to many times posted on track times, but I was surprised to see a 12.xx from the car. Untuned it ran 13.38 106.73, installed the tune and dropped to 12.80 @ 109.78, 30 minutes later.
Pretty good drop for everything down to the tire pressure being stock otherwise, I was impressed with the times for such a heavy car, I thought it would hold it back more.
Going in for ARH headers and a Vararam, then it's back to the track. All in all I am impressed with the feel of the car, nice driver.![Burnout](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_burnout.gif)
Obviously there are many variables, DA etc, but what are the common ET's for these cars stock-tuned stock-and bolt on's?
thanks
thanks
![Thumbs up](https://ls1tech.com/forums/images/icons/icon14.gif)
Yes that's pretty fast for sure.
I knew once the weather got a little cooler that the cars would pick up a little more.
My prediction for the quickest bone stock 2010 SS in good air is somewhere in the 12.6 or 12.5 range (maybe low 12.4s with just tuning?).
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
So that's about average for these Marc? I asked some other guys there with Camaro's last night, but no one had a sure answer, and I have not followed these too closely yet. I was more concerned with before and after the tune, then the actual ET numbers, but I would still like to know out of curiosity. Nearly a .6 drop in ET shows just how much these are held back.
EFI Live for the tuning.
8 sec potential, 12 sec slip
They could have easily dyno tuned it on a dyno so they had the file stored on a computer, then put the stock tune back in to make a pass or two, then put the tune back in from the dyno they previously did.
Or maybe they tuned it on the fly at the track. They do make wideband gauges ya know
My bet is on them doin a prior tune tho and just loading it up to see how it effected the ETs
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
The tune process was done prior to going to the track, returned to stock-ran, then tune down loaded and ran. It picked up about a consistent 20+ rhwp, and even more torque, across the entire band.
was this the same car that was in GMHTP last month and this month? it ran a 13.38 also, thought that was a bit of a coincidence... if so, that car gained 150tq @ 3300, thats alot of tq management...
Some people argue that the street (and the track) is a better place to tune a car. Dynos are just much, much more convenient and gives the power output numbers. But, as we all know, the numbers don't mean jack. It's the times that matter.
![Thumb](https://ls1tech.com/forums/images/smilies2/thumb.gif)
One of the 2010s you'd spoken to was my friend good Steve (there with his girlfriend Steph's Cyber Grey SS), they also ran in the 13.3s bone stock so the car obviously in need of some tuning.
![Werd](https://ls1tech.com/forums/images/smilies2/werd.gif)
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
As far as a 150 ft lbs of torque increase from tuning, if it's on the internet or magazines, it must be true...
![Angel](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_angel.gif)
I think that the 13.3 that you guys ran in stock trim is roughly the average, one or two have touched 12.9s and others have gone only 13.5s (depending on usual elevation, temp, fuel load differences etc.).
It might be LOL, my C6's A6 was pretty bad before tuning/TM removal and I think the newer ones (LS3 C6, G8 and Camaro) are even worse!
Nice guy, I think he ran 13.8 & 13.6 on Tuesday, but he might have stayed longer then I did.
Thanks for the info, I figured you were up on these things.
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
i said 150 at 3300... it went from 160 to 310... heres the chart:
http://www.gmhightechperformance.com..._dyno_run.html
The cars are heavy but the potential is certainly there.
![Mr. Cool](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cool.gif)
