to all of you doubters on weight!!!!!!!
#42
This is why your logic is flawed because you are not taking into account all the variables. Do not ever compare a manual car with a stalled car at the drag strip. It does not matter that you launch at 5000rpms,
You are right a manual car should always be faster in NHRA and IHRA both index the manual cars in stock eleimator 1 tenth quicker. 7.30 in the 1/8 gears and stall, OH YA and a 250 shot that more believable.
#44
Wow.
Low 7's with just a stall and gears on an A4. And another guy claiming all it takes is gears for an A4 to break into 11.9's.......
Being someone who owns a stalled A4 with a fairly large cam....and longtubes.....and custom y-pipe........and a shift kit.........and lid.......and cat delete.......and a magnaflow........and a tune.................... I doubt I'm in any position to argue with these two guys..........
I just wish I knew that info before......
#45
Yeah lets be real, comparing 98-00 with 01-02 LS1’s and saying that the average is the following is not realistic. Considering that the 01-02 cars came with different intakes, exhaust manifolds, camshafts, better flowing catbacks, and even lids from the factory. Your data is skewed, 01-02 cars are typically stronger on the dyno it is a well known fact, getting 305rwhp from an 01-02 is far from being a factory freak.
#46
Are we talking about NHRA or IHRA? Did not think so……………. Looks like the conversation is about 4th generation F-bodies and the fact that A4’s with stalls were much faster.
#47
#48
They are the only sanctioning bodies there are for drag racing. They should no what is faster in setting up there class rules. It stands to reason a stock car that puts 10 to 15 more horse power to the ground should be faster. 4th gen cars are very popular in those classes. I due agree in a stock car a converter picks your stock car up 3 tenths in a quarter more if you have mods a lot more if you have a big cam. Back on topic 7.3 in an 1/8 with just gears and converter is wrong maybe 8.3. Bone stock they were like 8.7 and for your info gears and converter will not change your trap speed much.
#49
No use arguing with people that are completely wrong. I doubt the guy you quoted runs 113mph with 335whp. I run 112 all the time with 360whp. The 1/4 time of 11.8 I could believe, but mph is determined by power. So this guy has less power than me but ran 1mph faster. Theres something more to this story. Just because you run a quick time once, that doesnt mean crap to me.
That's funny, I actually thought my trap speed was kind of low LOL.
I did in fact dyno only 335rwhp on a Dynojet and I did in fact trap 113.62 (I'd only hit the 113s twice, all of my other passes during that period were in the high 112s).
Keep in mind that 335rwhp on a dyno is not necessarily still only 335rwhp out on the track where the air is hitting the free ram air/filter/lid with a little more force and also where the MAF/IATs can take advantage of the extremely cold air that I ran those numbers in. It was probably the 2nd or 3rd best quality air I've ever raced in.
#50
Wait, you're doubting my trap speed?
Further a couple of them in here have no idea what a converter does, one guy saying it will only add 3 tenths and maybe more if you have internal mods like a camshaft. All I had was a set of headers and a lid, and just by changing the stock converter for a Yank ST3500 I went from 12.6’s down to 11.8’s, that is whole lot more than just 3 tenths, and I surely did not need internal engine mods to go quicker.
The top 50 stock internal with bolt on list would not be on this site if it did bear any significance. People keep saying it is not possible to run a 7.3 in a 4th gen car, and yet there are several cars on that top 50 list that have done just that. If I was running 7.5’s with a small 3500rpm converter and there were guys running quicker times with a looser converter some as high as 4600rpm it is not hard to figure out they were 7.3’s and low 11 cars.
#51
The problem is you are not talking to people with any common sense. I did 22 passes the day I went 11.87@113.5mph, My slowest slip was a 12.07@112.7mph, not exactly one pass in a million. I hit 113 quite a few times and at two different tracks and yet my car only dynoed 326rwhp. No matter how many times you put it out there these people cannot comprehend track elevation, density altitude, and the track itself all contribute to running quick times and fast trap speeds.
i dont have a scanner but i have 2 of my dyno sheets sitting in front of me, both have the same engine mods which is a trex, flowtech headers, and a lid..... my 6 speed put down 406rwhp and 368 lbft/torque then i put a built turbo 350 with a 4000 stall and with the same exact car, same engine, just different transmission it laid down 386rwhp 462lbft/torque now i did lose 20 hp through the automatic but i gained almost 100ftlbs/ torque !!! not to mention WHERE THE POWER WAS MADE!!! with the auto i made 462 lb/ft at 3000rpm and it stayed there til redline, the 6 speed made 312 ft/lb at 3000rpm and started growning til redline, so just at 3000rpm the stalled auto had 110lb/ft more torque, also my hp on the auto pretty much stayed the same and flat lined, at 3000rpm i made 308hp with the auto, at 3000rpm the 6 speed had 204 hp thats over 100hp less at the same rpm with the same motor!!! my peak hp with the auto had 386hp but it made that at 3750rpm til redline, the 6 speed made 406hp but not til 6250rpm, at 3750rpm it only had 252hp, thats 134rwhp difference!!! to match the 386hp my auto has the 6 speed had to be at 5500rpm!!! so yeah the 6 speed makes more hp but only for a split second then you have to shift and all that power is lost and you have to build it up again, i was 8 tenths faster in the 1/8 with the same set up just a different transmission!!! A STALLED AUTO MAKES PEAK POWER AT LOW RPM ALLTHE WAY THROUGH THE REDLINE!!! the whole time you are in peak power pretty much and the 6 speed everytime you shift you have to build that power up again for example at wide open throttle down the track at redline when you shift your rpms drop to around 4500rpm maybe a little less and at 4500rpm the 6 speed only made 292rwhp, now the stalled auto at wide open throttle will never drop below 5000rpm going down the track and at 5000 rpm it produced 356rwhp heck even at 4500rpm it made 344rwhp,...... also you have to consider TORQUE MULTIPLICATION!!! and TORQUE is what takes the weight of a 3500lb car and gets it moving from a dead stop
#52
I keep trying to tell these 6 speed guys but they dont get it
Do you think you can have more Torque on a chasis dyno than a flywheel dyno? If you think so I can understand our confusion I can say with reasonable confidence you will always have more torque and horsepower on a flywheel dyno. Your torque multiplication does not exist once your converter is locked up or past the flash point of your converter. So if you have a 347 cu ls1 with a stock bottom end making 462pounds of torque to the wheels that is special because that would be around 550 fly wheel foot lbs. I have never seen numbers even close to that that,it would actually be a very wild build on a stock ci engine without a power additive.
#53
#54
It's ok, I think he had a crazy torque spike, and is calling that his actual rwtq dyno #. It's cool, we'll just have to wait and see once the new car gets out on the track. That, or i need to get my car on that dyno.....I'd love to see what kind of #'s it would spit out, haha.
#55
Wow your car must be the only one in LS1 history to do that. I was looking through the dyno results on this page and there isnt a single car that has more torque than it does hp. You must have something very special done to your car. Hell I know of like 3 gas engines in History to have more torque than hp.
#56
#57
TH350
T56
Oddly enough, I just so happen to have a scanner, Oh yea, and a car with a Trex that had a T56 that went to a TH350.
Above are two back to back pulls. The only change is T56 to a TH350/stall.
Please....TEACH ME O WISE ONE. I mean, I know i don't know much....
T56
#58
First of all by not having more tq than hp I mean like massive abount more tq than hp, like you claim you do. I have yet to see anything even close to being similar to your car. Correct me if Im wrong(actually I know Im not wrong) the TREX is a cam that likes a lot of RPMs. So by your own admission "put a high rpm cam and you will have more hp than torque" you are more or less saying your set up has more hp than tq?
Heres Thunder Racings results of the cam:
http://www.thunderracing.com/dynogra...n=read&pgid=60
Heres a guy with a 4400 stall:
https://ls1tech.com/forums/2851051-post1.html
Heres another:
https://ls1tech.com/forums/dynamomet...o-numbers.html
Every chart I look at the tq is slightly more than hp or about 50 points less than HP. So tell me how you supposadly have roughly 75 points more tq than HP? And dont tell me its because of your Auto because 2 of the cars I posted were A4s for sure.
There is NO way you gained so much tq from switching to an auto.
"i have my dyno sheets sitting right in front of me and why would i lie about it???"
Post it up...
Heres another:
Post it up...
#59
#60
Heres another:
Post it up...
Heres another:
Post it up...
