Downsides to convertable?
Vert's weigh more...that only matters if your going to race
Vert's always seem to have more wind noise & road noise.
If someone gets pi$$ed at you, they are likely to cut the top. That's expensive to replace.
Vert's are very easy to break into.
If you ride thru a bad area in the hood you may feel more exposed and less safe than you'd like.
Being able to drop the top by flipping a latch and pressing a button is priceless.
If the weather is bad where you live that will take some fun out of the vert.
The car that actually got me seriously looking at F-bodies again was a triple black 94 LT1 Convertable.
I think Vert's ALWAYS need subframes.
Get what you want.
I've rolled with T-tops, I've had sunroofs, but nothing beats a 'vert. They are cruising cars, I love mine. As was mentioned, if you really want a 'vert, don't settle for T-tops, get one. You'll learn to keep a towel in the back seat (I do), you'll get used to bass that sucks with the top down (yeah), and the shake, the weight, yeah. If you want to go fast, get a stripper hardtop. If you want to have a fun cruiser, can't beat a 'vert.
Get what you want.
and how do they differ from the 98-00? Ive never seen a difference (besides the mirrors which changed in 00)
I have a 4th gen T-top car and a convertible, so I have a direct comparison for my opinions. I have subframe connectors on both cars too. Personally I would get another convertible for a weekend toy but would NOT get another one for a daily driver. As you can see in my sig, my 1995 Z28 convertible is my daily driver.
The post above has many very good points...
-I got my t-top car first, but now that I have the convert too the hassle with t-tops seems like a huge pain in the *** now. Just dropping the top in 5 seconds at stoplights is priceless.
-Both T-top and convertible cars NEED subframe connectors
-Both T-top and convertible cars leak, but a convert usually leaks a bit more (yes even my 42K mile T-top car with subframe connectors leaks!)
-You can absolutely feel the convertible flex, shake, and twist a lot more, even with BMR subframe connectors on my vert.
-I honestly don't notice any more road noise in my convertible, which I was really surprised by.
-If you get a convertible, get a low mile one and take really good care of it!
-I love both, but mainly b/c of the shakes, rattles and leaks (which still aren't terrible) I would not get another convertible for a daily driver. If it's a weekend toy you can drive it more easily and carefully, which could reduce the wear and tear on a convertible car.
That's my .02
i Yes, it does have a little cowl shake and when I installed an ORY pipe, I could not put the X-brace back on - I had to use the tunnel brace off one of my other cars. I'd swapped enough torque arms to shorter aftermarket ones that I had a couple tunnel braces on the shelf.
It is used as a cruiser. I would not build one to be a track car or even close to that. It is really nice to drop the power top on a sunny day and just roll. I installed an SLP airlid and P&P throttle body to try and make up for the extra weight and at least make it as quick as a bone stock coupe. It was too quiet, so I added the ORY and now we can hear an exhaust note when we want to. Seemed to add a handful of HP too.
i don't think i'd want a hardtop unless it was a lot cheaper though. test drive it and if you like going fast with the top down, its for you. however, if i had to deal with winter, i'd reconsider.
. Oh yeah forgot to add that you shouldn't worry about the roll bar thing, hell i have been to the track many times and i dont have one it just depends on how strict they are -shakes and rattles
-very loose and unstable handling
-IMO is doesnt look as good as the t-tops
-u need a roll cage if u run 13.9 or better
I got a vert only cuz it was a very good deal at the time for me. I still love my vert, its great on a nice summer afternoon or night
Also, verts attract ALOT of attention with the top down.
Weight difference is about 123 lbs from a vert to a T-top. I fixed that by removing my spare tire, jack, and replacing my stock wheels with lightweight Centerline models.
There is one member here, Cablebandit, who has a 9 second T\A vert at 4130lbs!!
Video under the vert section shows some of his runs.
As far as appearance,IMO, T-tops look better than verts with the top up, Verts rule all with the top down!!
well I still think your car is beautiful!!!
