General LSX Automobile Discussion Non-technical LSX related topics.
Intake leak? Huh?
Old 12-09-2008 | 06:31 AM
Vicinity's Avatar
Default Intake leak? Huh?
I've had this whistling/vacuum sound in my engine bay for a while, it's really annoying. Really really annoying. I wasn't able to figure out what it was, but I assumed it was the AIR or EGR (forgot what a 2001 has) leaking. Yesterday, my mechanic helped me with some stuff and I asked about it.
He said my intake could be leaking (and something sounded like a bent rocker arm or something, is that really bad?) I checked and the intake looks like its only held on by a few screws, so should I take it off and inspect? I don't want to **** anything up.
Thanks.
Old 12-09-2008 | 07:22 AM
conan's Avatar
Take a small tourch and JUST turn on the gas and wave it around the intake if the rpms start to rise on their own you have some bad intake manifold gaskets.
Old 12-09-2008 | 07:30 AM
the_merv's Avatar
^^Never heard of that one..I could see it working though.
Old 12-09-2008 | 07:33 AM
conan's Avatar
I have removed my intake several times with no problems untill the blower, finally got burned not changing the gaskets on the first start up with the blower. This is how I found my problems.
Old 12-09-2008 | 07:52 AM
Vicinity's Avatar
Ok, thanks. I guess I'll run to Wal Mart and pick up a mini torch.
Old 12-09-2008 | 09:16 AM
Vicinity's Avatar
I just bought a propane torch, opened it half way and weaseled it around the intake (avoiding the heads) and throttle body, it did not increase in RPM.
Old 12-11-2008 | 11:00 AM
Vicinity's Avatar
Bump. It sort of sounds like a supercharger. It's a whistling that increases with RPM's. Any ideas!?
Old 12-12-2008 | 01:35 PM
conan's Avatar
Try to check all the little vac hoses on the back of the intake. There's a few around the big hose going to the brake booster. Also get it to the driver side fender inbetween the wheel and bumper the air pump is in there try to unplug the harness and see if that is your noise.
Old 12-12-2008 | 09:35 PM
Red96TA's Avatar
Mine does this too.....almost sounds like a blower when its idling. I always just thought it was the because the cam made it suck more air. It almost sounds like a blower whine, just quieter. Find out what it is so you can tell me
Old 12-13-2008 | 12:21 AM
02 BLK WS6's Avatar
No need to disconnect air pump. Pull the relay in the fuse box under the hood. It will throw a code if it's not tuned out, but will aid in trouble shooting.
Old 12-13-2008 | 11:30 AM
samson_420's Avatar
Could be a pulley. . . . .good luck.
Old 12-13-2008 | 10:54 PM
LS1Formulation's Avatar
Power steering pump whining?
Old 12-14-2008 | 10:15 AM
Vicinity's Avatar
No, just replaced it the other day. Going to try the fuse thing later, thanks for the advice, guys.
Old 12-18-2008 | 01:51 PM
Vicinity's Avatar
Pulled the air fuse, at warmup the exhaust got louder, which was pretty cool, but no go on the noise. I'm about to go out there and start pulling every big *** hose I can find until I find that noise.
Old 12-18-2008 | 03:31 PM
jrob56's Avatar
ya mine makes a whining noise at idle too, last night i started the car as its been sitting for a month and i really noticed it then, i dont know what it is, but no codes or anything so im guessing its fine. im doing an ls6 swap soon maybe ill find the source then...
Old 12-18-2008 | 07:14 PM
Vicinity's Avatar
If you do find it, remember to let us know!
Old 03-27-2009 | 02:00 PM
jrob56's Avatar
update for you, i still have the whistle after the ls6 intake install, but everything seems to run real smooth and idle seems good too. i am gonna do the torch thing or buy some carb cleaner and spray it around some stuff, if i find something ill let u know.
Old 03-27-2009 | 02:17 PM
Joshiedoom's Avatar
Disconnect the belt for a few and see if it goes away. That will eliminate accessories. Check the PCV system. Mine makes a creepy whistling sound if i have my pcv valve turn one direction(truck valve.. not a poppet type.. )
Old 03-27-2009 | 06:35 PM
jrob56's Avatar
well i just did used the mini torch thing to check for leaks and found none, couldnt really get all the way to the back but it was enough to convince me! the duals will be going on tomorrow as scheduled. i was worried i was gonna find a leak and it would postpone the duals install...
Old 03-27-2009 | 06:45 PM
Martin HD-28's Avatar
Have you gotten it tuned after the intake swap? As far as I can tell, it's important to get it tuned.
