What would you do next?
Clutch then a rear. If that clutch goes on you, and it will with that kind of power, it could cause problems for your transmission because you will start having problems shifting. I wouldn't want to risk the transmission. Once that's done, go with a rear because you're an M6. Do you track the car or launch it hard? What tires do you run on the street/track? This will all matter.
