General LSX Automobile Discussion Non-technical LSX related topics.
I got $2500 to spend. Need Help!!
Old 02-09-2009, 10:07 PM
BlackBeautyWS6's Avatar
Default I got $2500 to spend. Need Help!!
Well as the title says I have $2500 to spend. Any suggestions people? My mods that I have now r in my sig.
Old 02-09-2009, 10:13 PM
Flaring Afro's Avatar
you have shocks? id get some good ones to help put down the power and have better ride quality with those springs
Old 02-09-2009, 10:18 PM
Z28SteveA4's Avatar
i would say a 12 bolt so u never have to worry about the rear or a pair of heads
Old 02-09-2009, 10:29 PM
Nooo I dont have shocks. And I was thinkin about a set of heads.
Old 02-10-2009, 01:01 AM
Texas 02 Z28's Avatar
I vote new rear end with some slicks! That'll be worth a lot more than heads imo.
Old 02-10-2009, 01:03 AM
SparkyJJO's Avatar
If you still have the 10 bolt that would probably be a good starting point.
Old 02-10-2009, 01:12 AM
Detoxx03's Avatar
Rear end or heads
Old 02-10-2009, 01:46 AM
Sunset'01Z's Avatar
how is your stock trans holding up?
Old 02-10-2009, 05:15 AM
Transgression's Avatar
AFR 205 heads gets my vote
Old 02-10-2009, 10:36 AM
kmdracer's Avatar
Get some shocks, and an adjustable panhard bar if you don't have one. With the springs you have, you'll need them.
BTW, I see you're in Hobbs. I used to live in Tatum (north of Lovington). We used to run down to Hobbs about once a month or so.
Old 02-10-2009, 01:35 PM
69_YENKO's Avatar
well no more then ten minuets ago I just called to the good people at TEA and ordered a set of TFS215's so thats where i voted to spend my own money. for you I would recommend building the suspension, looks like you've already added a lot of power mods and no suspension(at least listed in the sig)
adj. Tq arm
adj. lca's/phb
relocation brackets
SFC's
adj. shocks up front
under drive pulley
fuel pump(because your spraying)
that wont use up all your money
Old 02-10-2009, 01:39 PM
zracer323's Avatar
I say either the rear or a built tranny.
Old 02-10-2009, 01:45 PM
andrew69_04's Avatar
i've got some adjustable koni front struts if your interested in them.
Old 02-10-2009, 08:00 PM
LSXDoc's Avatar
I'm with this guy
Old 02-10-2009, 11:47 PM
01ssreda4's Avatar
i agree
Old 02-10-2009, 11:52 PM
Slow5.0.'s Avatar
My vote goes in this order.
12 bolt
built tranny
built bottom end
heads
Old 02-11-2009, 01:00 AM
Detoxx03's Avatar
Any decison yet?
Old 02-11-2009, 01:19 AM
sway99bird's Avatar
Go with a rearend
Old 02-25-2009, 07:51 PM
I still havent decided! I have some slicks already and Im gonna work on some suspension and the rear end before it takes a dump on me.
Old 02-25-2009, 08:18 PM
iowackers's Avatar
Definately the rear end 1st. That is the weak link if you start, I mean continue, to put the hammer down
