fiberglass hood
fiberglass hood
hello,i just put a fiberglass ss hood on my b4c 2001 camaro.i'm not able to use the stock hood shocks due to the hood being a little lighter,and just wondering if anyone had the same problem ,and how you solved it.is there a different shock i can use or maybe a prop rod.any help would be appreciated .thanks
another option is to just use one of the stock shocks, one of my old camaros had an aftermarket hood and it just had one shock when i bought it, held the hood up fine and didnt have any problems with it
i may have to put a new set of shocks on,even with the stock steel hood,i had to push on it hard to get it to move,but once it broke loose it worked fine.i tried them off the car and it took alot of pressure to break them loose to work .think they are bad ?thanks for your help.appreciate it!
Get new hood struts before you ruin the new hood. VFN now sells the proper struts or you can check with some other strut vendors. Your going to need 35lbs struts.
http://www.vfnfiberglass.com/site.htm
i have the same problem i bought a fiberglass ss hood and if i use the stock shocks it will break my hood. The hoods bends like crazy when u go to shut it and when u open it, it throws the hood up so fast it cracked my hood
