A few questions that I couldn't find answers for
I've searched around the forums and the net but to not prevail. So here goes...
I've got the Camaro listed in my sig. Its got Kumho Ecsta xs tires. 285/40ZR17 100W fronts and 315/35ZR17 102W rears. Max PSI on these are 51 however, what should I be inflating these to?
Next Q I've got is prolly just a rumor, I think. When decelerating, if you leave the car in gear, it uses no gas and the engine is just turning over due to the wheels spinning. What do you guys think?
Lastly, at what rpm on the highway does a stock Camaro with 3.42 gears get max mpg. I've heard a few different ones like 1800 rpms which gets me to about 85 or so. I figured that 65 (my area highway speed limit) with lowest rpms would be better as its lower engine rotation.
What are good gas saving bolt-ons or mods to do to one's Cammy?
If you didn't notice by now, I'm trying to squeeze out every drop of gas due to summer gas prices. Trying to save a few bucks at the pump to get some more mods in on the car later this year.
Thanks
-Mike
Thanks
-Mike
Mike. Please don't take this as bashing, but you may as well put a for sale sign on that beautiful car an let it go so a MAN can enjoy the vehicle and not whine about gas prices. I understand wanted to modify the car, but the car is ment to be enjoyed, not. "OMG am I driving slow enough in 6th gear to get 40 MPG in a LS1 v8?" Please, beat that beast and get that 12 miles to the gallon so you KNOW your having fun with a sports car; Not an eco box.
BUT:
Yes you use gas while deaccelerating, otherwise the engine would shut off.
Yes, the lower the rpms the less gas you use.
And get new tires.. Those are sissy tires.
BUT:
BUT:
BUT:
Thanks for your comments and your opinions.
For future reference your recommended tire pressures based on the vehicles weight are on the drivers door frame. The brand does not matter, nor does the tires maximum pressure. As fas as mileage, keeping her under 2k RPM without lugging the engine will do you best, you won't see much difference between 1600 and 1800rpm or whatever.
I can understand if you want to get some mpg out of your car nothing wrong with that. As for tires keep the pressure at what the manufacturer suggests which is on the driverside door jam regardless of tire size, its by weight of the vehicle which determines the psi for the tires.
I tend to keep the engine under 2k cause the exhaust and car styling is enough to make the illusion that I am going fast.
Thats kinda bullshit too bc if the rpms go too low then you will lug the engine and hurt mph, there is a happy medium.
Have a nice day...
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Thats complete bullshit. If the wheels are turning and the motor is physically coupled to the wheels via the clutch engaged then it will turn with no fuel, the momentum of the car is what is turning it.
Have a nice day...![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Have a nice day...
Have a nice day...
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
into the combustion chamber, but the engine isn't using any fuel?
It will still burn fuel, but it will burn less. LOL, So it's only 1/2 BS.
And this is what I found all over the internet. We need the Mythbusters to test this and prove it once and for all.
OBDII will shut off fuel injectors on decel if the engine RPM is higher than idle and the throttle is closed.
Even notice how you can decend a long grade in your LS1 without the exhaust popping the entire time?? Thats because the injectors are turned off, no point in adding unecessary fuel when the engine doesn't need it.
So technically you would use less gas by going down a hill in gear with the throttle closed than by coasting down the hill in neutral at idle.
Also incorrect.
spark plugs stop firing?
So theoretically, if you lived in Colorado & you drove for 20 miles going
down the side of a mountain, you wouldn't use a drop of gas?
I'm not calling you wrong, I've just never heard of this before.
So if you are going down hill in gear, your fuel injectors shut off & your
So theoretically, yes, you could go down a 20 mile grade with it in gear with the throttle closed and you shouldn't use a drop of fuel.
There is still fuel going into the engine when coasting or else you would totally lean out.. If this theory was true then while coasting in an M6 car if you stepped on the clutch the motor would die..
