General LSX Automobile Discussion Non-technical LSX related topics.
Weirdist coolant leak ever...
Old 08-10-2009, 08:03 PM
IRONFIST's Avatar
Default Weirdist coolant leak ever...
I was out and about Friday night when a giant cloud of steam decided to develop under my hood. I pulled into a gas station and had the car towed home... told myself that I'd deal with it in the morning.
Saturday morning, fill the car up with coolant, turn it on to find the leak... no leak. I tell myself maybe the car randomly over heated... and drive it around.
Car works great all weekend, go on a date, go run errands, no problemo.
Today.. leave work to go to taco bell, small coolant leak... dripping but nothing substantial. I drive home with a pepsi bottle full of water just in case I run too low.
Get home, fill the radiator up all the way with water, turn on car... coolant spraying everywhere because the leak is dripping onto the pulleys, of course since all the pulleys are wet I can't tell what one is getting dripped on...
Massive torrent of coolant dripping off of rear of engine, but I'm guessing it's cause my driveway is at a slant and it's just trickling back there and dripping.
Ideas on where to look?
Old 08-10-2009, 08:17 PM
Revelation Z28's Avatar
check your throttlebody if you havent done the bypass mod. also the crossover tube for the heads in the front
Old 08-10-2009, 08:39 PM
RacerXLs1's Avatar
Maybe the weep hole on the water pump???
Old 08-10-2009, 08:59 PM
IRONFIST's Avatar
Well looks like the leak has gotten bigger and is from behind the waterpump... it's pouring down the front of the block and onto the crank pulley.... and then spraying everywhere of course.
Time to rip some **** apart I guess...
Old 08-10-2009, 09:37 PM
chadaclysm's Avatar
Eh, sounds like a lot of work. Might as well slap an ls6 in there
Old 08-10-2009, 09:41 PM
txredss's Avatar
Water pump gasket failure's are common on all the late model GM V8's. Usually you can just replace the gaskets and your good to go but you might want to replace the pump and thermostat while your there depending on the milage of the vehicle.
Old 08-10-2009, 10:44 PM
IRONFIST's Avatar
80K miles, looks like the second pump... should I change it?
Old 08-10-2009, 11:16 PM
99huggerorangeZ's Avatar
+1,mine went out just went out @ 35,000 miles but my car sits in the garage alot and i only put 3,000 miles a year on it. i installed new gaskets and has been good since.
Old 08-11-2009, 12:35 PM
IRONFIST's Avatar
Funny you'd say that, I will be slapping on my LS6 heads while the car is down and out....
Not an LS6, but one step closer.
Old 08-11-2009, 12:38 PM
Gray Ghost's Avatar
Classic water pump leak...just had that happen on my 05 as well. I'd replace it unless you are sure it is a gasket.
Old 08-11-2009, 10:02 PM
white_camaro's Avatar
if its from the weephole replace the pump, if not id save the money and just do the gasket.
Old 08-12-2009, 03:51 PM
IRONFIST's Avatar
The water pump came right off, took 30 minutes....
I don't think I'll be replacing the pump, just the gasket. It comes off so easily I might as well wait for it to go before replacing.
