If my car was only a 1/2" taller...
then I would be able to back it up my ramps.
damn lowering kit!!
So it looks like I need to buy a good floor jack...so what do you all recommend??
damn lowering kit!!
Get a craftsman or something not to expensive... An some nice jack stands... Jack stands are all you need to really worry about... Your not gonna get under the car on a floor jack anyways! Are you? lol
hell no, not without some sort of redudancy. I wouldn't trust my life under a jack. I need at least a 2 1/2 ton jack and some jack stands. Would sears be a good place to start looking?
((((((Administrator))))))
I just bought one for my dad at Costco. 2.5 Ton and very low profile. I beleive it was $80 with jack stands. Make sure you get one that is low enough. My Craftsman pro floor jack will not get under my Saturn Sky Redline. I'll be using pop's next oil change.
i also say harbour freight they have a light weight aluminum 3 ton for like 80 bucks.
or i got my gm performance parts jack at walmart for 80 bucks but its heave as **** and i dont know if it would be low enough it not on my car(im also lowered with hypercoil springs)
to the op i would check out harbor frieght they have good **** at good prices
Last Summer I had a $150 Gift Card to spend at Sears and wanted a nice jack to use in the shop. I used every bit of it to get a Craftsman 4 Ton Low Profile. I figured Low Profile for the cars, and 4 Ton would be heavy duty enough for even my bro's 06 Duramax. Took it outta the box and put it together with no problem. Tried it on my 99 Sonoma and it did the job, but I noticed just a little bit of fluid on the shop floor once I pulled the jack out. Not a big deal. I'm sure the seals are new and maybe dry from sitting in the box on the shelf. Well through the next dozen uses, the leak doesn't cure itself, and actually starts to leave a bigger and bigger puddle. Okay, I'm not happy, so I take it back and exchange it. Right outta the box the new one leaks. And the same thing happens. It gets worse and worse. I more than few times add more fluid in the hope that the thing comes out of it. No luck. I decide I'll take this one back and hope that third times a charm. I call up Sears to see if they have one in stock, and they tell me this Jack is now discontinued. So I can't exchange it. So I decide to call the customer service number in the owners manual to see what can be done. I talk to them and they say, there has been alot of trouble with the seals in the rams going bad. They ask for a copy of my Original Receipt by email and they'll get a ram out to me ASAP. I send them the copy and get no reply. I wait like a month and still nothing. Finally I get tired of waiting and figure even if I do get a new ram, whats to stop it from ending up a leaky POS as well? So I simply return the Jack for store credit. And thats where I'm at as of now. I'm still searching for a high quality replacement. I've done multiple searches online, checked out reviews, and testimonials and I believe yours is the first good review of ANY Craftsman Jack out there. Like I said, I'm glad yours has worked well for you and I hope it continues to do so, but the experience I've had with them hasn't been pleasant. To the O.P. you will definitely want to do some looking around before you buy the first jack you see. I hope this little story hasn't bored all of you. I'll definitely keep my eye on this thread to see what you decide on. That way I can take a look at it and maybe get the same one. Good luck.
![Offtopic](https://ls1tech.com/forums/images/smilies3/offtopic.gif)
![Hijacked!](https://ls1tech.com/forums/images/smilies/myhijacked2.gif)
