Anyone ever damage their O2 sensors by going in a deep puddle?
1 Post
Well I got trapped last week on a main road and i couldnt avoid a huge puddle of water that was up to my door. I drove thru it and moments later the car started to run like pure ***. I checked the codes and it was the O2. These O2s were only a month old and that will be a quick $200 down the drain
![Cry](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cry.gif)
Usually the O2 disruption is temporary when water is involved. I would wait a bit for them to dry up. Usually they bounce back. But if not, it should not cost $200. Denso O2s are about 50 apiece i think. I'm assuming its only your two rear O2s.
At any rate, yes it happens, and best of luck.
^^^ is what happened to me. I drove through a big puddle earlier in the day then later that night I ran a 04 GT. During those three runs my 02's fouled out from being wet then fouled #7 plug so I raced and beat him badly all 3 times from a dig. Afterwords he gave a bs excuse something about his fuel pump. I told well I'm on 7 clinders and still won. His reaction was priceless. Back on topic if your 02's are only 2 months old shouldn't they be under warranty still.
I had a similar issue when it rains really hard, car bucks and simply wont perform. I unplugged all my O2 sensors and sealed the connectors with die-electric grease= Problem solved
1 Post
