true dual exhaust compared to y pipe
#43
#44
#47
I had Magnaflow TD's run out the back on my WS6 and a Magnaflow with FM Y-merge setup on T/A. The TD's sound about 1000 times better than the Y setup. No rasp at all.
The only reason people swap LM7's into LS1 cars is if they blow their motor and need a cheap replacement, that is the only reason.
#48
346>327
#49
^^323ci..
There's your problem..if you had a 3" TD setup you would have noticed a difference.
I'm actually in the process of going to TD's.. I changed my Torque Arm and bought this one from UMI Performance..
I also bought the 3" X-pipe Kit from Summit, I'm using Flo Pro Twistie Mufflers. My goal is to make it look like this..
#50
Check out https://www.drgas.net/ you can build what you want.
