Question on center consoles
Guys,
I have a rather odd ball question here. Does your center console, rather the second piece of the center console that your shifter and the gear indicator stick is on.
Is that 110% solid on your car or does it have play (back and forth, door to door for example) I dont know if I broke a clip while installing it back on the car or not.
Does everyone know what Im getting at here or do I need to explain myself better?
Thank you!
Thank you!
Ok I found a pic on google and got slightly creative just to be 110% sure we are on the same page. The small piece **outlined in red** thats on TOP of the center console is what's moving **direction of movement in green** Like If I grab at at the very top (right by the ligher) I can slightly move it side to side as shown. Were talking an inch, more than likely less than that of overall travel.
I Have the exact same problem you do. The part with the shifter boot (front I guess) moves left right. There are some clips that help hold that part together, but I have not really investigated as to if they are worn or something. Mine doesn't move unless I physically move it, but I'd like a fix or ideas. The screws are tight on mine. Kind of did this after I changed my shifter.
