St. Louis Area Shops
I have a 02 Camaro and i broke the corner off the block where the outside starter bolt mounts up. I was wondering if anyone knew any shops in or around the St. Louis area that could weld it back on? Thanks
I would get the phone book out and look up welding companies that specialize in aluminum . The engine will probably need to be removed so a good weld can be applied.
None of those shops can perform a block repair. Those are bolt on install type shops. Bier Brothers is the last place I'd go even for a car wash.
As said you're gonna have to remove the engine and take it to a metal fabrication shop. You may try C&S Metal Works. They make all kinds of stuff for the military so I'd bet they be able to help you out.
That would make me nervous lol
Im not trying to be a dick. But if it all has to be disassembled i would just buy a shortblock or just buy a new block and put it back together.
Just google JB weld. People use it to seal cracks in the engine blocks, radiators, gas tanks, valve cover etc. But in all seriousness, whats the worse the can happen? the piece will just fall off again? and if it does, its going to cause no additional damage. If welding the piece back on require you to drop the motor, it worth a try with JB Weld
