Leaking power steering fluid
I'm leaking power steering fluid and I don't know what he could be. I have to refill up every couple of days, I'm thinking the pump may be bad or something. Do guys have any ideas.
Get someone to start the car and turn the wheel while you're under the hood looking.. Mine had a loose nut that was causing it to leak and drip down on the alternator.. Also check the line and the little plastic nipple part (be careful, it's paper thin)..
